Old 06-05-2014   #11
Re: Potential Buy 1997 GSX
http://www.ecmtuning.com/forums/show...578#post650578
ok got some logs tonight before the laptop died (left it on while at work)
anyrate some wierd stuff happened also unfortunetly no logs when it did.
first log i missed 4th gear causing knock. wide band reading 10.5-10.8
2nd log i started at like 2500rpms and it knocked enough to get my cel to trigger. (had never done a pull from that low rpm yet. wideband was reading 10.8
3rd pull cant remember if anything special happened.
anyrate so wierd stuff. after these pulls i have like 15min of my trip left to get home and you can't speed due to cops, deer, etc. so doing the speedlimit.
I get into town and i have to come to a stop sign and make a right. well when i went into neutral the car was idle surging and the wideband was swinging all over the place full lean full rich, I tapped the gas and settled down. went to get going and it started again and hte car started bucking really bad, quickly popped it inot nuetral (doing like 5mph now)... if it matters car had 1/8th of a tank of gas left....
anyrate put it into gear and tried again stuttered like normal when into 2nd gear and statted stuttering real bad almost like a blown i/c piping. for a spilt second. wide band once again swinging like crazy.
tapped the gas and the wideband settled down and car went on like normal. no idle surge, wideband was runnign normal (from that stopsign to my house is like 1/4mile)
pulled into the drive way all is well nothing weird, shut the car off no sounds of bubbling, etc just quite as can be. Oil's fine, coolant overflow is normal.
couldnt find anything wrong.
