Old 06-10-2014   #11
Re: Potential Buy 1997 GSX
My experience with lower temp T-Stats. If you're cooling system is working as it should, it will work great to keep your temps lower. However if you are having overheating issues, all it does is delay the inevitable. It never actually fixed anything for me, simply delayed it by a little bit.
One other thing I forgot to mention. If you're oil cooler setup is the type where the coolant cools the oil, you could potentially benefit from switching over to an air type oil cooler. Takes a little bit of tax off the coolant system, and every little bit helps.
