Old 06-16-2014   #12
Re: timing way to high at idle?
Did you instal the ICS motor correctly? Typically 2500rpm is the outside of the threshold for the motor to control. There is a correct and incorrect position to install it if memory serves correct.
What is the BISS screw set at?
What is your base timing set at?
