Old 07-21-2004   #2
Check in this order:
Alternator fuse
Alternator
Battery
The electrical system should be something like 13.7-14.0 volts when the car is running, which would prove that the alternator is working. If the system is not charging check the fuse, is 80 or 90 amps I believe. If the fuse is good then it's your alternator.
When the car is off the battery should read close to 12 volts which would prove that the battery is good.
