Old 11-06-2014   #4
talonsway
Drives: 1995 eagle talon TSI
Had enough time today to rip out the cruise control and install the non cruise cable. Really gives a guy some space.
Also got my TPS adjusted correctly. And started the car up ( found out my starter is starting to go out too). But still having problems with the idle. When i first start it and it is cold it will not idle unless i give it gas, not until the car is a little warmed up that it will idle. Once it is warmed up it will idle smooth, but once i give it gas and let go, the idle wants to hang at about 2k. And then when it settles back down the A/F go all the way lean and the car stumbles and wants to die. This is the first time this has happened and this started after i rebuilt my throttle body. Any of you guys know what i can check? i can get a log if it would help out.
talonsway is offline   Reply With Quote
