Old 04-07-2015   #5
Perkul8r
Perkul8r's Avatar
Drives: 91 GVR4
Re: DSM Ecu in Non DSm car.
It would be possible, but take a lot of time, money, fab, work and not work as well as S300. The major problems are the Honda is a speed density and distributor car, while the DSM is a MAF and wasted spark twin coil cam angle sensor car. Plus you would need to swap in every other DSM sensor. If you were going to run speed density with DSMLink, then the S300 is better at speed density anyways, since it the native way the stock ECU runs.
Thanks for the info on it.
I am just gonna go with S300. Just will take time to learn the little things on it. Just gotta mess with it a little before I put my other motor together.
