Old 04-08-2015   #2
Re: Sparktech vs. Modifying Ignition Coil Dwell Time
Talking with spark tech before they said the stronger spark not only will prevent spark blowout but give a more complete burn producing better numbers. Is that true? Meaning, is there really a difference between just not blowing out the spark and providing a "full/complete" burn?
This is true, that is why you want to run as wide a plug gap as possible. This is also why some guys prefer copper (or silver) plugs vs. platinum or iridium.
My opinion: Try the amplified dwell time tables and see if it works for you with the expectation you'll eventually kill the stock coils and potentially have to upgrade to the SparkTech (or buy some replacement OEM coils if you're satisfied with the results). I would run as little amplification as possible to meet your needs until it becomes more widely known how the stock coils are holding up.
