Finished up the stronger rear 3rd member mount. Just need an alignment now.
My tube notching skills are improving. I started using a digital angle finder, the results are below:
I added a center support to the mounting locations, to make sure there were no issues with the design, in regard to the bolted joint preload. The rear end was used as the fabrication jig for these:
And finish cut:
And the final product installed:
www.maperformance.com
