Old 11-20-2016   #20
mark4g63t
mark4g63t's Avatar
Drives: 95 Talon TSI
Re: 97 GSX -The Rebuild
Wasn't cranking because of a bad clutch switch. I unplugged it and now it cranks over. Which is weird because in link it showed the switch working.
Tried starting it but I think the gas in it is a couple years old and bad. (Has fuel and spark and compression and the 1g cas is not 180° Backwards.) It will crank and start so a second then die/ sputter like bad gas.
Going to drain the tank today and put in a couple gallons of fresh 93.
BW8776, e-85
