Old 10-17-2003   #6
PSI2HI
If you're gonna tap into the oil filter housing you have to make sure you tap into the port after the oil filter. If not your gonna be worse off then tapping to the head as you'll receive dirty oil pre filter. And that'd put you a lot worse off.
I know or least i heard AGP was recomending running oil from the head as well. But wehn i last talked to PTE they said they were no longer going to warranty turbo's that were taking oil from the head which in my opinion is BS because if the factory took it from there why cant everyone else. But i guess thats up to them. Their turbo's have been failing no matter where you tap for oil.
Nick
straightlinespecialties.com
