Old 11-18-2004   #5
520Talon
I use some really long ones of the correct thread. Just take your tranny bolt with you to a hardware store (ace or hardware hank as they have bolts or fastenall). I use three nuts (large enough the bolt slides through) between the block and the stand to give myself so more room to work on the rear seal and not have that nuckle busting square plate so close. I have several sets of these bolts as I would often have two motors on the stands to make swaping accesories and motor swaps go quicker. You can have a set if you want.
520Talon is offline   Reply With Quote
