Old 12-04-2004   #4
JasonR
Guest
Tournaments Won: 6
Posts: n/a
Originally Posted by 90lazerRST
I noticed that my gears were a lil sticky last night.. and then today.. on my way to WI, i noticed it was getting very hard to get the car into and out of a gear ( any gear). Byt the time i reached the end of my journey to rice lake, I pretty much couldnt get it into gear with out smashing it in. I pulled into the drive way, took it out of gear and before i let the clutch out it died. I couldnt get it into ANY gear no matter what i did. Also, it would start for a good 15 seconds and die again... that might not be transmission related. I have noticed something leaking a little from the passenger side somewhere. I cant figure out exactly what it is.. thought it was oil but it wasnt. Thought it was power steering fluid.. nope.. i duno, I need help. I cant get home until i figure this out. Thanks.
Where is it leaking exactly Josh. Take a flash light and look under tranny if you can. You can drain the tranny fluid and inspect. Then make sure correct amount when adding new tranny fluid. Use large wrench for leverage. Hope for the best. Hey is the car running well besides the tranny. Jason.
