Old 12-08-2004   #11
Raptor
ConArtist
Raptor's Avatar
Originally Posted by ecoli
Why is SS the best? Doesn't SS hold in heat? Why would you want SS over aluminum? You don't see aluminum in many kits because it costs $$$, but you often see it on race setups.
If your IC is efficient at cooling the air, you will have more trouble with alluminum heatsoaking off the engine etc. SS works much like shielded piping, keeps the cool air in the pipe and the hot air from heat soaking. SS is more expensive than alluminum typically also which is why you see less of it. Alluminum is much easier to work with but it is inferior to SS or even shielded steel for IC piping.
Quick Precision Racing, Inc.
"Always Raising the Bar!"
651-488-7774
