Old 12-14-2004   #8
Raptor
ConArtist
Raptor's Avatar
Re: Shifting weird, explain gear lube plz!
We have it in stock, I just went through and explained to him in a PM however that it is not a cure all and he would probably be wasting money since his tranny is already making noise etc. I would use it for the purposes of protecting a good tranny, improved shifting, and maintained viscosity under load and higher RPM, reduced friction is also good. Putting it into a tranny that is at best questionable would likely be a waste of cash. I am not turning away business by any means, however I don't want people to buy stuff just because we sell it. Or for any other wrong reasons. If you change the fluid with the much less expensive fluid from Wally mart and the like, and the old stuff isn't full of transmission particulates, and the noise has dissapeared etc making you believe thet transmission will be worth the investment, then I say go with the redline, it is the best fluid IMO. Hope that helps.
Quick Precision Racing, Inc.
"Always Raising the Bar!"
651-488-7774
