Old 01-26-2005   #6
santa
Boost Spike
santa's Avatar
Re: Few "minor" problems
If you have the time, do a leakdown test and compression test. That will give you a deff. if the headgasket is blown. Drain your oil and check it for coolant of any sort. The white smoke is deff. going to be coolant. That is the only thing that smokes white that your car can burn, unless its and automatic. Which still has a vaccum modulator. If the diaphram in those is ruptured than it can be sucked in by engine vaccum. Which in turn makes it burn and turns your exhaust White. So a few more details would be great about the car it self. Miles, trans, mod's ect... the list goes on. The spark problem could just be fouled plugs from burning the coolant as well. Grab the DVOM and ohm the plug wires, they should check out around 5,000 ohm's per foot. You also could have a water pump leaking as well loosing that much coolant. Let us know what you come up with. Just do a good one over of your car.
