Old 02-03-2005   #7
belittle
Re: stock 2g turbo and bov psi question
Originally Posted by everglow
I am curious how much psi the turbo throws and what the stock boc can hold psi wise since everyone says it leaks and the 1g holds 22psi I am curious what the 2 can handle
From personally experience with the 2g bov it is a piece of junk. Like said before it can only hold up to 12 psi if that. The engineering went way down for the BOV on the 2g. Now about the T too small. You can run xxpsi with it but the fact is it wont be effiencent above 13-14 psi. Once you raise it above the stock pressure it does nothing but blow hot air and basically poop out after 4.5K. I know for a fact my T25 set at 15psi would fall to 10 psi at about 5K in any gear but 5th. Definatly first mod for a 2g is a different turbo, intercooler piping, and BOV.
95 Eclipse GSX:1g 7 bolt motor(don't ask):dsmlink:MLS headgasket:arp's:Kevlar timing belt:Apexi dunk 3in exhaust:680cc FIC injectors:selfmade 3" downpipe:ACT 2600 clutch:Fidanza Flywheel:14b turbo:greddy type s:Hard piping:Shep "race spec" tranny
http://img151.exs.cx/img151/6900/image81tz.gif
belittle is offline   Reply With Quote
