Old 03-24-2005   #17
Re: Power troubles
Alternator is a very easy thing to accomplish on a DSM. Put it on and tighen the belt is reverse order of how you took the old one off. The belt needs to be tight enough to no slip/squeak, but not so tight it wrecks the bearings. After you install it, at idle turn on the headlights (highbeam), AC with full fan, and your rear defroster...if its going to slip/squeak now will be the time.
