Old 04-27-2005   #33
At-Least-It's-An-Evo
At-Least-It's-White-Again
At-Least-It's-An-Evo's Avatar
Drives: 98 iVTEC
Re: ARP Head bolt install help needed.
100ft-lbs is a bit excessive. 85 ft-lbs should be good enough, but most peopel will go 90-95 ft/lbs for the hell of it.
The main problem with putting moly-lube on the thread in the block is that it can get trapped under the studs on our blocks and cause problems. You only have to go finger tight because a stud will do fine as long as it have plenty of threads to hold onto. And you don't want to tighten the stud on it's own down so far that it the bottom of the bolt hole causes some kind of sideways force of the stud.
'04 Honda Ricer: stock
