Old 12-13-2003   #5
The factory mani's drop off around 6700 with a 20G or larger turbo, that's where the aftermarket mani makes the difference. To really make it worth it though, you need to raise the limiter so you can get an extra 1800 rpms of power instead of 800. At this point you're running into valve float issues if you have old worn out valve springs somewhere around 8000 rpms. That's why the intake is considered one of the last things, you need almost everything else to make it beneficial. The stocker is not that bad, people have gone 10's with it.
