Old 05-19-2005   #3
Onefast99gsx
Re: Logger Connection on Car
What Palm Software are you using. Is it pocket logger? Also, 1g or 2g? Also, what is your cable? I have laying around a pocket logger that i don't use anymore due to dsmlink but i've tried using other off brand software with the pocketlogger cable and it didn't work. The software had to be specific to the cable. Multiplex engineering sells logger cable OBD-II interfaces for like $85 but you have to know up front what software you will be using with it because when you order you have to tell them which byte it will read. So make sure you have the right software for the right cable for the right car.
PS- sounds like you have a 1g the way you describe with the 1 red wire. Is your hot sync cable a dual type, meaning is there a serial 9 pin connetor AND a usb connector. If so, i bought a cable like that for mine and it didn't work. I had to have the direct cable without the USB. If it's got a USB connection y'd into the cable that may be the problem. With my electronics experience i just rewired my cable to make it work.
