Old 06-16-2005   #4
unreal808
Mr. Me Too
unreal808's Avatar
Drives: Suzuki GSXR
Re: Car is dead
When you try to start the car and it clicks one time, do you lose power on everything for a short time like 2 seconds?
When you try to start the car you will lose some power but not everything. Like the signal lights should not go out with the key turned to the start position or the dash lights like the SES or the oil light should stay on untill the car starts.
If you only loose power for a short time you could have a bad ground, try running a wire from the negative post to the engine block, and crank over the eng if it turns over you have a bad ground.
Take her to the limit!
