Old 06-22-2005   #4
xluciusx
Send a message via ICQ to xluciusx Send a message via AIM to xluciusx Send a message via MSN to xluciusx Send a message via Yahoo to xluciusx
Re: Battery Relocation
I think I'll pic some 2 gauge up after work.
So should I be running a line from both the positive and the negative battery terminals to the same old lines? You know, normally it goes postive baterry terminal to starter and fuse box and negative battery terminal to chasis ground and engine ground. So I would do the same with the battery in the trunk just with a long wire connecting the terminals to the original lines
I'm not sure I understand what you are saying about the chassis to starter bolt ground...
xluciusx is offline   Reply With Quote
