Old 06-23-2005   #4
Re: Prop Shaft Carrier Bearings...Bad?
For future reference, you can check your carrier bearings by grabbing the driveshaft and yanking it back and forth. If it hits the metal housing on either carrier bearing, it needs to be fixed or replaced. The common symptom is a thumping sound from the rear on hard acceleration.
