Old 08-11-2005   #5
Re: Need Advice on cracking wastegate pipe, suggestions
The WG should be hard mounted, at least before the WG. It shouldn't be an issue. I guess you could put a flex on afterwards if you have it routed back in. There really isn't a point though as there shouldn't be a flex section in the exhaust anyway (before where the WG would mount back in). It all should be hard mounted.
