Old 02-24-2011   #21
Re: MAP's 2008 Evolution X GSR Build Thread aka Project GGX
The stock tune is awesome on those cars. You can pick up a good 50-70whp just from tuning them and doing no mods.
Old 02-24-2011   #22
mlomker
*Resting In Peace*
mlomker's Avatar
Mlomker you can see used the SAE correction factor.
That sheet was from the Fall `09 dyno day.
Old 02-24-2011   #23
munchgsx
munchgsx's Avatar
Drives: 2004 Corvette M6 F45
STD
What correction factor was used? I don't see it on the MAP dyno sheet. Mlomker you can see used the SAE correction factor.
Old 02-24-2011   #24
How many bone stock X's have you guys really SEEN in person?
Old 02-24-2011   #25
v8klla
v8klla's Avatar
Project GGX huh? What did I win off the Facebook comment contest?
Haha didn't know you suggested that, I told Dan we should call it that before the "contest" but I'll see if we can't get something over to you!
Originally Posted by mlomker View Post
Naw, just means he'll have 10 guys working on the car to minimize the downtime...and all of the parts choices will be bizarre, depending on which vendor gives him free stuff.
Basically just like the Evo X in Modified magazine.
It will progress slowly, but to accomplish our goals she's going to need a built lower end And the majority of the parts will be MAP this time around, we learned our lesson in that regard lol.
Solid numbers though. MAP - have you baselined any other 100% stock X's?
We've had some come through but we can't recall any names, we need a Cobb like system to keep track by car lol.
Chris Carey, President
Modern Automotive Performance
P: 763-545-3800
E: chris@maperformance.com
Old 02-24-2011   #26
Woot for another X in town!
My advice, convert to e85, keep the tune conservative, have fun on the stock turbo w/ bolt-ons for a bit. AutoX the thing (let's organize!). Have fun with it! Do a stock-frame turbo upgrade (perhaps something custom? ) and push the stock bottom-end a bit. Do some IM testing w/ your rev2/rev3 products, a ported stock TB, and the boomba 75mm guy (see the current TB discussion in the tech section) and see what does what. Maybe even a SMIM?
IDK, just focus on wide powerbands and reliability. That's what make evos evos!
Old 02-24-2011   #27
Maybe even a SMIM?
We're now in the day of cast
Old 02-24-2011   #28
Do it!
Old 02-24-2011   #29
Muahaha here we go, get ready to move this discussion to a new thread!
Two of the four best performing manifolds (that I've seen) for the evo8/9 are SMIM, the other two are cast, one of which is a ported stocker. Granted, the SMIMs have a ton of CNC parts so they are not just pure sheet metal, so I think with MAP's fab department a SMIM would be a real trick piece that I'd love to see tested out (with various TB's).
Old 02-24-2011   #30
You do realize this is a parts development mule, don't you? I would guess the BPU mods have already been beat to death. I'm guessing this thing is going to go big real soon because there's not as many parts available for that crowd. Besides, Chris has a pretty nice daily driver in case the GGX is in the shop for an extra day or two.
Old 02-24-2011   #31
I am in your head stealing your thoughts!!
Old 02-28-2011   #32
v8klla
v8klla's Avatar
Confirmed that she's still rocking stock exhaust this weekend as I finally got it up on the lift, should have the first modification (air intake) with dyno results done this week!
In the meantime, I used to rock these wheels on my Evo 8, yay or nay? And yes I know it's dirty, we got several inches of snow on Saturday and as I outlined above this is my daily
P: 763-545-3800
Old 02-28-2011   #33
Looks nice, what size are they? Narrow wheels look funny on X's IMHO
Old 02-28-2011   #34
Murlo26
Murlo26's Avatar
Drives: 17 Honda Accord
The rims looks good, might look a bit better with a lil wider. I think 9.5" are the perfect size, that's what I wish I went with.
It's hard to tell until you drop the car, I'd assume you are going to drop it a bit at some point. Or you can rock the monster truck style like me
Old 02-28-2011   #35
What is the stock wheel size on a X?
Old 02-28-2011   #36
18x8.5
Old 02-28-2011   #37
hmm ok, must be the offset that makes scheides' look so sunken in then.
/off topic
Old 02-28-2011   #38
v8klla
v8klla's Avatar
These are 18 x 9.5" Work Emotion CR Kai The outer edge of the wheel lines up almost perfectly with the body line, although I do need some wider tires, they are 245's right now I need 255's or larger. Anyone know if I will have issues with rubbing in the rear?
P: 763-545-3800
Old 02-28-2011   #39
Murlo26
Murlo26's Avatar
Lomker should know, he runs 265's on his 9.5's. I don't think he rubs.
What offset are you running?
Go 265's if you get new tires, unless it rubs, fill that rim out!
Old 02-28-2011   #40
mlomker
*Resting In Peace*
mlomker's Avatar
What is the offset? I run 18x9.5 +28 and it's perfect. Anything more aggressive and you'll want to roll the rears. I'm running Star Specs in 265 but I could run a 275 in an NT05/narrower tire.
