Old 02-23-2011   #1
v8klla
v8klla's Avatar
MAP's 2008 Evolution X GSR Build Thread aka Project GGX
Quick Jump / Thread Navigation:
MAP 3.5" Short Ram Intake / Dyno Results
MAP Turbo-Back Exhaust / Full System Upgrades / Manual Boost Controller / Dyno Results
407whp / Stock Turbo with Fuel Pump Rewire
*NEW* 603whp / 503wtq / Full Spool ~3300
Well, we've been selling Evo X products for a while now (we actually make several of own in house) and previously had to rely on our local MN Evo X owners for any product development or testing. As our plans for the platform have expanded significantly we decided to bite the bullet and pick one up for ourselves.
I found this beauty at a dealership in Madison, WI (about 250 miles from our shop) and simply couldn't ignore the fact that the previous owner only managed to put 13,9XX miles on it in over two years! The body is pristine and the only flaw I could really find was some curb rash, but the stock wheels will be coming off soon anyways
We've got big plans for this project, which is also my daily driver, but I can't spill the beans just yet. This thread will document the entire build process including installation guides, tech articles, and dyno results. Below is what we're working with as a baseline on 91 octane, it's hard to tell but this thing is super rich, a tune alone should yield substantial gains. Your comments and/or suggestions for the project would be greatly appreciated
Chris Carey, President
Modern Automotive Performance
P: 763-545-3800
E: chris@maperformance.com
Old 02-23-2011   #2
Murlo26
Murlo26's Avatar
Drives: 17 Honda Accord
Re: MAP's 2008 Evolution X GSR Build Thread aka Project GGX
My suggestion....2.3L overbore motor I think AMS is working on one but we know it will be uber expensive. Design a cost effective one.
Or use the 4b12 motor to make a hybrid Evo X design with 2.2-2.4L of displacement that can still rev.
I am excited to see where this goes.
Old 02-23-2011   #3
Nice project. GGX sounds/looks dirty as a word.
I'm sure they will come up with something good, it looks like the mitsu crowd is finally starting to embrace "stroker" motors.
Old 02-23-2011   #4
mlomker
*Resting In Peace*
mlomker's Avatar
Who'd want a X? I hear they are slow and expensive to mod.
Old 02-23-2011   #5
Sweet. Good luck with it, and it'll be interesting to see where it goes. You said it's your DD, so I'm expecting it won't get too nutty?
My only recommendation would be to run a 100mm throttle body.
Old 02-23-2011   #6
Is it 100% stock?
Old 02-23-2011   #7
mlomker
*Resting In Peace*
mlomker's Avatar
Naw, just means he'll have 10 guys working on the car to minimize the downtime...and all of the parts choices will be bizarre, depending on which vendor gives him free stuff.
Basically just like the Evo X in Modified magazine.
Old 02-23-2011   #8
Is it 100% stock?
That's what I was wondering, seems a little strong for being completely stock. Although I wouldn't be surprised if the X's are more underrated by the factory than the 8/9's.
Old 02-24-2011   #9
Project GGX huh? What did I win off the Facebook comment contest?
Old 02-24-2011   #10
Murlo26
Murlo26's Avatar
I thought about this more....the current power level.
This seems to be at or around the '10 and '11 stock power level with the better tune. Do they have a new updated flash out now (the dealers) that they put on the car?
Still trying to figure out how the hell it made that power stock, lol.
Old 02-24-2011   #11
mlomker
*Resting In Peace*
mlomker's Avatar
We'll have to wait and hear if it is stock. My car hit 280 with bolt-ons and no tune. If boost is bumped or there's at least an intake/cat delete then it's quite possible.
Old 02-24-2011   #12
It's right in the first chart. It looks like it hits 20psi by 4000rpm and falls to about 15psi. I'm not sure what they run stock.
Old 02-24-2011   #13
mlomker
*Resting In Peace*
mlomker's Avatar
I think it is 21-22 so close enough.
Old 02-24-2011   #14
Guys, how many times do we need to go over this? Dyno numbers are just that, numbers. What is important is the gains they will see based off this baseline. Who really cares what a stock car puts down, as long as it is a solid baseline, they are building a foundation to document x% power increase with X mod.
Old 02-24-2011   #15
Yup. I've seen stock 2010's do 23psig on the dyno, but I'm sure a lot of that depends on loading so "only" 20psig on a DynoJet doesn't surprise me.
Solid numbers though. MAP - have you baselined any other 100% stock X's?
Old 02-24-2011   #16
Every car must be the same though! Numbers should be exact from stock car to stock car, if they are not, we must decipher why these minuscule differences are happening.
Old 02-24-2011   #17
Must be a .0035729mm variance in throttle body diameter huh? lol
Old 02-24-2011   #18
Murlo26
Murlo26's Avatar
Well several of us have seen dozens of stock X's on dynojets. We aren't saying anything about the numbers except they are higher than a normal X on a dynojet stock.
It's either a freak or he has a mod unknown to him because of the fact its used.
It's on 91 too which is weird. As Chris stated on EvoM it would be beneficial for it to read lower to show better gains after putting MAP parts on there.
I like how people around here get butthurt because we are curious about something...
Old 02-24-2011   #19
munchgsx
munchgsx's Avatar
Drives: 2004 Corvette M6 F45
Bone stock and running richer then 10:1.
Old 02-24-2011   #20
What correction factor was used? I don't see it on the MAP dyno sheet. Mlomker you can see used the SAE correction factor.
