Old 11-02-2005   #21
1slowdsm
Now 1 second.....slower!
1slowdsm's Avatar
Drives: 1993 Talon AWD
Re: Turbo Upgrade Advice
Just get all the upgrades you want and when the parents ask, just say "it was there when we bought it." Normal parents wouldnt know, unless they're mechanics themselves. I had the exact rust problem with my N1 exhaust, haha. You can get a nice front mount off ebay and paint it like Vicious said. They'll never notice...
Old 11-05-2005   #22
95tsi
95tsi's Avatar
Drives: a pos
Do the big T-28, and dsmlink if possible. If you do get the T28 make sure you have your O2 housing ported out. I did the same thing and had boost creep problems until I got the housing ported. Stock injectors should be good for a while but you will want to replace them to make the full potential out of the turbo. Add in a new intercooler and you should be good for low 13's maybe a 12. Best of luck.
Old 11-05-2005   #23
Originally Posted by sleepy2lazy
just fyi.
The act2600 would put alot alot more pressure on your crank.
This increases your chances of getting crankwalk.
No it doesn't.
Old 11-07-2005   #24
Outlaw1
Resident Redneck
Outlaw1's Avatar
He's saying the 2600 takes more pressure from the TOB side to release the disc, which pushes the crank into the thrust bearing harder.
No it doesn't.
'07 Z06 Black/Black 2LZ
10.48 @ 136.86 w/1.65 60'
Old 11-13-2005   #25
4G63Spyder
4G63Spyder's Avatar
whatever you do, don't do an 18g...I got one on the cheap, and it takes forever to spool...nto fun for a street car, but makes life great ot highway speeds...lol
Team 3M TA3
Ban bad drivers, not fast cars
4G63Spyder is offline   Reply With Quote
Old 11-13-2005   #26
What are the specs of your 18G?
Old 11-13-2005   #27
4G63Spyder
4G63Spyder's Avatar
it's just a straight out the box Greddy 18G, not ported/clipped. I don't have the specs on it...why?
Team 3M TA3
Old 11-17-2005   #28
SlowTsi
Originally Posted by ecoli
Ha, lag lag lag lag lag.
Just put a FMIC on it. Your parents might notice that monstrousity Supra sidemount hanging down all wacked out in your wheel well.
lol
That is what I was going to say for obvious reasons. Defainately not as fun as a good old 50 trim on the 2.0.
Its hard to suggest anyhting without knowing what you want performance wise and what you want to spend. If you know someone with a known good 14b, you could pick it up cheaply enough and get a little more boost out of it. Buying a random one may cause you to spend time and money bolting up a crappy turbo.
If your budget can stomach it a big 28 or even a 16g variant would be nice. If you don't see yourself doing cams, the small 16 is fine.
New owner of ecoli's PT67 :) and Brian's 2g magnus :)
another 500whp stock motor 2g?? maybe a windowed block?? we will see :D
SlowTsi is offline   Reply With Quote
Old 11-17-2005   #29
clean2g
Boost Junkie
clean2g's Avatar
Drives: I teleport
Originally Posted by SlowTsi
lol
Yea someone I know had a good 14b so I'm just going to use that. I'll go all out when I'm able to build my motor later on. I was just afraid I might blow something up or screw something up if I went to a t28/16g with all my good luck
