Old 11-01-2005   #1
clean2g
Boost Junkie
clean2g's Avatar
Drives: I teleport
Turbo Upgrade Advice
I have a 97 GSX with ACT 2600 clutch, catback exhaust, boost controller and running at 15 psi on my stock t25. I want to upgrade to a bigger turbo but I can't get a front mount yet because of my parents. So I was wondering what are your thoughts on upgrading to a 14b and a supra side mount? With a supra side mount it will just look stock from the outside and my parents wont know I did anything. Also, what supporting mods would I need for a 14b upgrade, if any? I know it may not be the best upgrade but I think it would at least be better than my t25. I'm tired of getting harassed on the road and not being able to do anything about it.
Old 11-01-2005   #2
94talonawd
94talonawd's Avatar
Re: Turbo Upgrade Advice
wait.... you parents will yell at you for having a frount mount? What about your exhaust? Shouldnt they yell at you because of your exhaust instead? LOL
SOLD
94 Talon AWD
Big 16G
SAFC-II
99 Civic D16 - EVO3 16G - Hondata S300 - Xenocron 4bar@21PSI - RC750cc's - Eagles/Vitara - Compcams
12.3@114, 1.81 60ft
-On it's way to 11's....
Old 11-01-2005   #3
clean2g
Boost Junkie
clean2g's Avatar
Drives: I teleport
Well.. yea but it came with the exhaust when I bought it
Old 11-01-2005   #4
T28/Big28 would probably be your best bet.
Old 11-01-2005   #5
EclipseGST
EclipseGST's Avatar
Drives: Short Bus
I agree with Kracka. Either that or a 16g (small/big/evo) would do you just fine also. Your going to get sick of the 14b after awhile and be askin the same question again. So I'd save up over winter and just start slowly buying things. I'd get bigger injectors, fuel pump, S-AFC or DSMLink, and a 16g or T28. Good luck.
Originally Posted by shoutbox
Old 11-01-2005   #6
clean2g
Boost Junkie
clean2g's Avatar
Drives: I teleport
cool, thanks guys!
Old 11-02-2005   #7
slowbubblecar
Big Turbo Monster
slowbubblecar's Avatar
Drives: GTS and E55
you could also run a 20g with a supra sidemount if you have the other supporting mods. I ran it without a problem that way at least
7/25/09
Old 11-02-2005   #8
Plus the T28 is a stock bolt on, unlike anything else including 14b's. Nice, easy and simple. The stock IC is good enough unless you're going to run crazy boost.
Old 11-02-2005   #9
dumb_ricer
Hates Everything
Drives: Neon
Get a FP Big28 or a T28 or something like that.
Also, I didn't see a downpipe listed, or I am just blind, who knows which. Get a 2 1/2 or 3in downpipe as well, that will show some gains.
420A > LS1 > All Else
I > All else
Old 11-02-2005   #10
clean2g
Boost Junkie
clean2g's Avatar
Drives: I teleport
Alright, thanks everyone. I want some power but not too much for right now so I think I'm going to go with the t28 and leave the stock intercooler. And yea I need a downpipe. With the crankwalk nightmares I've been having I'd rather wait to go big so not to help speed up the process. .. yes two days in a row, I've had crankwalk nightmares lol.
Old 11-02-2005   #11
Khadgar
Can't Actually Wrench
crankwalk is just an excuse to upgrade
Old 11-02-2005   #12
Get a 2.5" downpipe along with testpipe; you are going to want either a fully ported o2 housing or a tubular one. Do you know what kind of catback you have?
Old 11-02-2005   #13
howslowcanyougo
Older than Dirt...
howslowcanyougo's Avatar
Drives: IX EVO MR/SE
Skip all the BS and go straight to the 67Trim, you won't regret it!
Till something breaks........:-P
Let the madness begin...
Old 11-02-2005   #14
Ha, lag lag lag lag lag.
Just put a FMIC on it. Your parents might notice that monstrousity Supra sidemount hanging down all wacked out in your wheel well.
Old 11-02-2005   #15
howslowcanyougo
Older than Dirt...
[QUOTE=ecoli]Ha, lag lag lag lag lag.QUOTE]
Till I can get a stall installed <?>, "Lag Monster" is my middle name.....:-<
Old 11-02-2005   #16
Anti-Lag
Old 11-02-2005   #17
sleepy2lazy
sleepy2lazy's Avatar
Get a downpipe. get an uicp / blow off valve. Get an intake filter (pipe if you really want it).
Then upgrade your stock turbo to a direct bolt-on t-28. Raise boost to around 17psi. You would feel the difference. You won't need supporting mods on the t-28 unless you go higher. 17 should be safe. Just don't beat the crap outta the car.
I wouldn't go 14b. Stock to Stock, why not just get a bigger upgrade?
Old 11-02-2005   #18
sleepy2lazy
just fyi.
The act2600 would put alot alot more pressure on your crank.
This increases your chances of getting crankwalk.
Old 11-02-2005   #19
clean2g
Boost Junkie
clean2g's Avatar
Drives: I teleport
I have an Apexi N1 I believe.. but theres a hole where the muffler meets the pipe from rust.. damn salt, so I guess I'll have to get that fixed before I do my upgrades.
Originally Posted by sleepy2lazy
fyi.
Bahh I know.. it's a long story. I was going to get a ACT 2100 but I had such a limited time to install a new clutch because my factory clutch went out and this is my only car. So I ended up getting a ACT 2600 with 1k miles on it from a friend.
Old 11-02-2005   #20
You could put a front mount on and paint it with a very light coat of flat black so it doesn't stand out.
