Old 01-25-2011   #101
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Re: 1991 talon 500 hp project
Almost half way there! Have fun in Cali.
Old 01-26-2011   #102
s1ngletracker
s1ngletracker's Avatar
Drives: A BMW
the hard half comes next :P
Style's automotive engineer
Old 02-27-2011   #103
way2fastalon
IS Broken :-/
way2fastalon's Avatar
well today i pulled out the damaged piston as stated before in another thread. It went boom after getting here rod is fine bearings are even fine normal wear.
scoring is a lil excessive but will still run as is it didnt run long enough after the hole to make a mess in the oil galleys im still pulling the oil filter housing off and cleaning it out .
Old 03-24-2012   #104
way2fastalon
IS Broken :-/
well its been some time since i have posted last .. i have disappointing news
so today i found out i wasn't sold .020 wiseco pistons
after the fact i had the very rare unheard of crank-walk a week ago with loose main and tight rod bearings ??? and cant blame oil starvation i had 80 psi at 70 mph i had 15-25 at idle hot i ran good oil all the time 20w50 vr1 with a zinc additive
my block was bored over .020 and i set my ptw to .023 and run a loose ring gap back in 2010 when assembled left me with a very tight .03
now luckly i did that cause the engine ran like that for 2 years with standard size pistons i ordered .020 soo witch brings me to here now whose error mine or the place i bought it from not giving names at this time
make sense of all the issues i have had in the past with it from frying 11 turbos no matter where fed replaced 2 front covers and oil pumps ,oil filter housings,everything oil related still cooked turbos
1991 Eagle Talon awd
2.0 fully built lower-end
+more mods to list
Old 03-25-2012   #105
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
How did you not know they weren't .20 over? I guess that would be your fault. I don't build engines but I remember when I bought stuff I double and triple checked with the shop when I picked up my parts. I think your shit out of luck. But on the bright side you might be able to build it up to the actual title of this thread. 500 awhp dsm! Good luck
Old 03-25-2012   #106
Engine builder should always double check all parts before putting them in the engine. That sucks though, did you measure the diameter at the top or bottom of the piston to determine their size?
Old 03-25-2012   #107
way2fastalon
IS Broken :-/
point is they are standard my purchase order says .020 over
picture is when i first got it all together what it looked like
+more mods to list
Old 03-25-2012   #108
way2fastalon
IS Broken :-/
i would have checked if i had a good mic ... but people with those are hard to find and you cant use a cheap one so i took the shops word for it ...
+more mods to list
Old 03-25-2012   #109
way2fastalon
IS Broken :-/
im still shooting for 500 but i keep getting raped
+more mods to list
Old 03-25-2012   #110
viridionplague
according to this article http://ferrarichat.com/forum/faq.php?faq=haas_articles 20w50 oil would be horrible for your engine. all you need is some pressure to create oil flow, but high pressure does not mean high flow and good lubrication.
not saying that oil starvation caused your problem but could have been a contributing factor based on this article.
Old 03-25-2012   #111
20w50 is run by a lot of dsm/evo guys, I kinda doubt that would hurt anything.
You should be able to tell by the part number on the pistons (or the box) that they are standard or overbore-sized pistons. Always doublecheck your work.
That being said I've made some pretty big mistakes in my time so don't let it get you down! Just fix it and move on, that's all you can do!
Old 03-25-2012   #112
How do you know they are not .020 over? That is 3 human hairs per side, so we obviously can't make that assumption from a picture. Like Scheides said, the numbers from the top is going to be the best bet.
Old 03-25-2012   #113
evotuner
evotuner's Avatar
Drives: 2004 Evo 8
that sucks man, good luck with gettin her back up and running
2006 WW IX RS 396/404 - SOLD
Old 03-27-2012   #114
way2fastalon
IS Broken :-/
well they are .20 over but what strikes me is they measure 84.4 at the top and 85.4 at the bottom of the piston over a 1 mm of difference ? map was telling me they taper at the top ?
+more mods to list
Old 03-27-2012   #115
way2fastalon
IS Broken :-/
Thumbs up Re: 1991 talon 500+ hp project
so my new build is going to be as follow's
2.0
Carrillo rods H beams
e85 pistons 10:5:1 ( still looking for the right ones ) that make me happy
might have to go custom pistons
stock mitsu crank
acl rod and main high stress coated
still looking for a set of used solid lifters pain to adjust but worth the power-band
and kelfords 272s nuff said
evo 8 valve springs i dont like bc because of the binding i keep reading about kigglys are $$$ not practical for dd
i have a slick hx40 custom built ... with super 60 pro compressor wheel ... love that thing. its in a bep housing want to see how much you can push one
small h1c exhaust wheel so 6/12 comes on like 3100 full spooled by 3500
spools amazing ! so far has it flowed 52 lbs a min at 27 psi on Link
going full auto im building the trans myself sick of failing syncro's so looking for a 2g awd auto trans 96-98
dont like the factor of drive-train loss. I know auto will be faster in the long run
and i have seen many new upgrades for autos from manual valve-body's and high stall locking torque converters
loving technology is catching up with the dsms ...
Fuel system now after trial and error i have found over building your fuel system is a better idea than not enough fuel from a tuners prospective
so the fuel system is 2 wallbo 255 hp feeding a aeromotive a1000 under the hood going to use -8 line looking for high impedance injectors digging the better spray pattern and the better atomization of fuel
some may say this is over kill but the car is getting a hx52 twin scroll in the future after maxing out the turbo system i have
+more mods to list
Old 03-27-2012   #116
What FMIC and SMIM? Might as well wait on the external pump until later. Check out the Bosch 044 external too, I chose it over the A1000 that I was going to use originally. More flow and more reliable.
Old 03-27-2012   #117
93gtpeater
Drives: cbr 1000rr repsol
Sounds like you have a window in your block in no time. Is this going to be a diesel motor?
Old 03-27-2012   #118
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
I wouldnt switch to an auto till you get the 5 spd running great! No issues! Your whole build thread is issue after issue. I know its a dsm but making it an auto wont change reliability. Just my .02
Oh and are you shooting for 500? Or 800? You can do 500 at DB with a simple fuel setup.
Old 03-27-2012   #119
How do u rape yourself?
Old 03-27-2012   #120
Tachyon
Tachyon's Avatar
Drives: Icarus
To echo this post:
Agreed with the oil weight. In a high stress / race environment use oil that best matches your most extreme operating temperature. Too thin and you'll probably get good at spinning rod bearings.
That being said, switching to a thicker oil caused sufficient oil pressure to blow smoke on my turbo (no balance shafts). I am porting my oil filter housing to compensate.
The best way to get a block machined is to have the pistons in hand then give them to the machinist along with your PWC. I've seen ' 020 over' off by enough to screw up my engine builds by having the block bored before I had the pistons.
The more mistakes you make, the more experience you gain. Rinse and repeat for best results over the course of a lifetime.
-Sebastian Vettel
