Old 05-18-2010   #141
123abc
wants to be sideways...
123abc's Avatar
Drives: Loud cars
Re: Project Winter Beater
Time for a weekly pic update...
Took it bombing around on some of the gravel roads here. I've learned that I have a lot to learn about how to control an AWD car on gravel. It sure is a ton of fun though...
Originally Posted by Matt D.
Originally Posted by 93GSX5SD
Old 05-18-2010   #142
Very nice beater.
Old 05-18-2010   #143
123abc
123abc's Avatar
Drives: Loud cars
Very nice beater.
Why, thank you. It looks decent from about 10-20 feet away. lol
Old 06-07-2010   #144
123abc
123abc's Avatar
Drives: Loud cars
The car has developed what feels like fuel cut at about 4k. Drives around perfect until I start going more than 50% throttle and the boost goes above 12 psi.
I've checked:
-Plugs
-Mafs
-fuel system for leaks
-Boost leaks (none)
On my datalogger the only thing that looks fishy to me is the injector duty cycles go from 20-30% all the way to 80 something percent right before it cuts out.
As of right now, I want to say the pump might be taking a crap? It's an evo 9 unit that I replaced in the winter time a couple weeks before swapping motors.
Old 06-16-2010   #145
123abc
123abc's Avatar
Drives: Loud cars
So I think I've found the problem. I took the cop setup off a few days back to inspect things and ever since it's been on like 3 cylinders. Well I took the cop back off today to check the plugs, put it back on and it ran fine till i touched the gas again. Then it was missing. I took the cop off and sure enough, one of the wires were pulled out of the stock plug on the cop side of things.
I crimped it so it's hardwired for now to get me to work. When I get to work, I'll solder it up until I find a stock plug again.
Old 06-19-2010   #146
123abc
123abc's Avatar
Drives: Loud cars
Well it drove fine on the way to work but still cut out under load. Pulled it inside the shop right away and soldered the 3 wires up. Pulled it out of the garage and it was back to missing again. On my lunch break I took it home and would only run right if it was between 2500 and 4k. Anywhere else in the rpm range and it would be on 3 cylinders.
I know for sure the number one cylinder isn't firing for whatever reason because I can cut the number one injector on my datalogger and it doesn't change the 3 cylinder running. I'm waiting for some motivation to hit me today and get my ass outside to mess with it some more. I have a stock coil pack and wires I picked up from Twack, just waiting for said motivation...
Old 06-19-2010   #147
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
Drives: Cyborg from Japan
Yeah I didn't like my COP when I had it on my car. It looks sexy, but performs poorly. I'm sure the stock ignition setup will fix all your issues.
-1990 Mitsubishi Cyborg 4WD-
Old 06-19-2010   #148
123abc
123abc's Avatar
Drives: Loud cars
Mine's been great for the last 2 or so years. I don't understand why it has started giving me problems now.
Old 06-22-2010   #149
123abc
123abc's Avatar
Drives: Loud cars
Having the stock coil pack and good wires on it (Thanks Twack) got it back to driving status but not full on boosting yet. Still fuel cuts after I changed out the sock on the pump with a brand new one in hopes I don't have to change the pump. Also checked the mafs and it seems to be in good working order. I read with those if you tap them with a screw driver at idle they shouldn't change readings at all, but a bad one will. Having the screen off the 3 in. gm maf wouldn't be causing this, right?
It's acting like it's running out of fuel before the injectors though. IDC's shoot way up from 65% way up to 115% on one of my pulls right before fuel cut. That's how my Laser acted before I put the evo9 pump in.
Old 07-06-2010   #150
123abc
123abc's Avatar
Drives: Loud cars
So I've now replaced all 4 injector plugs with newer ones off a 420a and still no difference. What I don't understand is I'm getting 11.7 v on both wires that go to the injectors. Shouldn't I get 12 + on one wire and the other is a ground that the ecu operates?
I'm going to swap my evo 9 pump back in and also re-wire it and see if that helps. I'm seriously out of ideas. I really want to run it this weekend at the autocross.
Old 07-19-2010   #151
123abc
123abc's Avatar
Drives: Loud cars
So after another week of thinking and tinkering on it... I think I've fixed it. It still leans out up top but that's because I have the stock pump in there still. But it pulls like it should for 12 psi. What fixed it was a new fuel filter and putting some injector cleaner in with about 3/8 tank. When I took the filter off straight dirt was coming out. Pretty nasty actually. I should've paid more attention when twack said the tank is pretty dirty...
Before, I'd have to set the translator box to around 480's to even drive the car anywhere. After driving it around with the cleaner in the tank, I started noticing it running smoother. So I messed with the base adjustment knob on the maf-t and it's been running fine set to 560's again. I went on a 20 min cruise last night on some dirt back roads and can say it seems to be back up to where it should be. I could tell the difference through the day. I tried doing some 2nd gear donuts in a parking lot and it just bogged, no power. I tried it later in the day and it was not a problem, just ripped the lot up in 2nd. hahaha
I plan to swap the evo9 pump back in this week and then I should be good to go with a fresh tank of 93 octane.
Old 08-12-2010   #152
123abc
123abc's Avatar
Drives: Loud cars
Thanks to Ryan (MustGoFaster) I'm now rolling on 245 series sticky's:
So if anyone is looking for some really wide wheels on the cheap, go get some 3/s wheels and be prepared to grind.
Old 08-17-2010   #153
123abc
123abc's Avatar
Drives: Loud cars
Finally had my transfer case leak fixed today. Had the local chrysler dealership run my VIN through and turns out my 91 Talon has never had the recall done. So they put an order in for the only t-case seal in MN and it arrived today. An hour later and I had a leak free t-case. Felt so happy. No hassle at all, I was very happy.
Just received my 3 quarts from Jack's transmission dot com also today and have to say, this is the best fluid I have ever used in my transmission. Use to stick with Penzoil Synchromesh and recently had some cheap stuff from work which was the worst ever... Put this fluid in and what a difference it made. Transmission makes way less noise then before, shifts a whole lot smoother. It really is a treat.
The car is just about ready for the cookout. Need to swap the Evo9 pump in and still have to have my wideband o2 bung welded in the exhaust. Still too many things this car could use but I'm really happy with it at the moment.
Old 09-07-2010   #154
123abc
123abc's Avatar
Drives: Loud cars
Still daily driving the talon. I had to drive my Stratus this weekend to the Dell's with my woman's family. It was so frustrating driving a slow car, I was not happy at all. The more I drive the DSM daily the more I want to sell the Stratus...
Car seems to still be running good. I keep having a problem of sucking water through my intake pipe. I need to make a box around the filter to water-proof it. The main area I think it's coming in is where the stock sidemount use to be, that hole is still wide open. Once it sucks water in my i/c pipes get water in them and my MAFs gets water on it. Won't let me rev above 4k when this happens.
I will say though the last few times this happened I was blasting up a dirt road when it was down pouring pretty good. If I drive around normally or on the highway and avoid standing puddles, I'll be okay.
Old 09-10-2010   #155
123abc
123abc's Avatar
Drives: Loud cars
Just some pics:
Dirty DSM:
Old 09-16-2010   #156
123abc
123abc's Avatar
Drives: Loud cars
Received my poly sway bar bushings for the front today in the mail. Also ordered front control arm bushings and torque solutions drive shaft bushings.
I now almost have my complete suspension bushing kit. I have:
-Front subframe
-Front and rear sway bar bushings & endlinks
-Rear upper control arm bushing
-Front control arm bushing
I plan to get the rear subframe and mustache brace bushings from Tuner Nation and the solid toe links off jaysracing.com.
I also scored some used front Gab HD rally shocks and some springs:
Anyone know anything about them?
Old 09-17-2010   #157
notsostockgalant
3g camaro owner
Drives: 88' camaro 400hp 327 sbc
Well GAB's are pretty much manufactured by KYB. KYB just revalves them per GAB's specs. Most reviews say that they are pretty stiff as well.
notsostockgalant is offline   Reply With Quote
Old 09-17-2010   #158
123abc
123abc's Avatar
Drives: Loud cars
Thanks, did not know that. Know anything about the springs? There looks to be two sets of front springs, one set is really tall, the other looks normal for a 1g awd. Any ideas on them too?
Old 09-17-2010   #159
notsostockgalant
3g camaro owner
i have no clue on the springs, unless they were bought as complete assemblys new and were taken apart for some reason. the taller springs would make things pretty firm i would think.
Old 09-19-2010   #160
123abc
123abc's Avatar
Drives: Loud cars
I asked the guy I'm buying them from if he knows anything and he said he doesn't. He said he parted out a GVR4 and these were with it. We'll see when they get here.
On another note, I was also able to locate some Noltec rear mustache and rear subframe bushings along with a set of Ingall's rear adjustable control arms. This completes my bushing collection and I just need to either get the Jays Racing toe eliminator links or weld the stock ones solid. Anyone have experience with either?
