Old 11-11-2009   #1
twack
It was a auto get over it
twack's Avatar
Project Winter Beater
Some of you may have seen it for sale here, but i bought it from matt j.
When were loading it on the trailer i see a pile of oil under the car so i figured it had a hole in the block. Owell at least i get my trans. so i bring it home and dont even look at it till the next day. after some hose clamps it held coolant, OK OK getting better. put oil in, and what do ya know it holds oil and pressure in both oil and coolant. Awesome so theres no hole in the block!!! i check all around and fix some small stuff here and there. OK its time for a compresion test, holy crap its 180 across the board. Im getting happy at this point. I hunt down the main issue to be a beyond dead fuel pump. so i get one from a buddy for free and what do ya know it starts!!!!! so now im just waiting to find some intercooler hoses for it and making it look decent.
Here is what i had to work with
Took a wire wheel and destroyed 18 years of midwest rust on the suspension and repainted them
cleaned and shampooed the interior
It runs!!!
Roughed up that flat black and threw some gloss black down. I think the black is tacky but its just a fun car that wont be the prettiest, its a beat up twin of my 92 talon.
I got rid of the nastiest rust and painted the bare spots. like i said not the prettiest but not to bad
since im not going to buy rims for and i want to keep with the twin idea i painted these rims black to
Ive been cleaning up the bay to look nice while waiting to find some stock intercooler pipes, it will get cleaner then this trust me, but a big start. ya the oil drain is leaking but that to will get fixed
Im going to try black with this engine, got to do something different then my other car.
in the shadow of its brother
dont have any intercooler pipes now so i have it run staright with no intercooler. its on stock boost its more then fine "we dont need no stinkin intercoolers". aside from rip in the flex pipe it idles and runs pretty good for not having the base timing set.
like i said the old pump was the problem, and was the worst looking pump ive ever seen. i got a free one from a friend but didnt have a strainer so i had to make do, its ok you can laugh.
When my 1st dsm got floded i lost anything that was fabric pretty much. so in restoring that car i made some center console side panels. I didnt want to waste the time to fimd some and i was rewrapping everything in the car anyhow. Those have held up for 2 or 3 years now. The winter beater needed the same center console panels, so i used the old ones as patterns and made some new ones. super simple: cloth and cardboard.
the black ones are the old ones and the gray ones are for the winter beater
because this is a super budget build, im also going to be making my own hatch cover and ill be covering that to obviously
panels in action. they are just set there so they are not screw in yet
I dont have a 2 din bezel for the stock radio so for the moment i made a panel for behind here so it wasnt a giant hole
made the panel for my hatch cover. the black one is different because that one has a cage. I still need to make bracing for it but it will look the same
traded a spare 1g BOV for a new knock off type s, not sure what im going to do with this cause everything on the car so far is stock.
Friend brought over a better "non-intercooler pipe" that had no kink
Old 11-11-2009   #2
twack
twack's Avatar
Re: Project Winter Beater
enough of that nonsense i went and got the pipes and threw on the intercooler.
dont worry i got a real 1g bov that will eventually get on
here is the hatch cover, still has 2 small openings on the sides where the trunk panels are supposed to be but i think ill pass on caring that much
Old 11-11-2009   #3
92pearltt
Drives: 91 fwd stealth tt/ 99 SL
How did you get the engine bay so clean? Just hit it with a power washer?
92pearltt is offline   Reply With Quote
Old 11-11-2009   #4
awd-drifter
'2of9'
awd-drifter's Avatar
Drives: Racer Van V6
lookin good man. keep it up!
ლ(ಠ益ಠლ)
Old 11-12-2009   #5
Looks nice for the money you have invested!
Old 11-12-2009   #6
Goddamn its crazy seeing cars like this and cars like Alpha's at the same time. If you know what you are doing and some luck, you can get a pretty nice car for not alot of $$.
Keep the updates coming dude.
Old 11-12-2009   #7
twack
twack's Avatar
first off you need emissions gone andthat fire wall pad removed. then i rinse, degrease with bucket and rag, rinse, wash with car soap, rinse, dry with large towel. i use a small electric power washer for all rinsing.
Old 11-12-2009   #8
123abc
wants to be sideways...
123abc's Avatar
Drives: Loud cars
Looks awesome! Now you just gotta get rid of that ugly worthless ABS.
Originally Posted by Matt D.
Originally Posted by 93GSX5SD
Old 11-20-2009   #9
twack
twack's Avatar
so i decided ill try the ebay BOV but couldnt deal with that nasty purple
So i decided, since im going to want some music at some point, i would clean up the stock stereo. it was all rusted over and i just cant let something like that go back in my car, so out came the wire wheel again and cleaned it right up
i kept the paint off the heat vent just a lil clear coat
Because of a power steering leak i did pull out all the ps stuff, very messy job, but it really cealns up the bay. It will be a pain inparking lots but if it dont work and i dont need it, im taking it out. I am also probably taking out the ABS as well.
Old 11-20-2009   #10
looking good
Old 11-20-2009   #11
123abc
123abc's Avatar
Drives: Loud cars
Fuck yeah we're taking your ABS out this weekend! I got the prop valve for it. Just have to fab up a couple lines.
Old 11-20-2009   #12
Wow, I'm gonna need you two (123abc & twack) to come help me with my 1g sometime, cleaning up the whole engine bay!
Old 11-21-2009   #13
It's easier and far better looking to just get the 4 factory front lines. Bending tubing always looks like crap unless you've got the nice benders and some skills. Don't forget to take out the wiring harness and ABS controller in the passenger side B pillar.
Old 11-21-2009   #14
Great job.
Old 11-21-2009   #15
123abc
123abc's Avatar
Drives: Loud cars
I've already done one ABS delete on a 92. It turned out pretty good:
What we did was re-use 2 of the previous lines and tweaked them a little bit to work. He had found the other 2 that run to the prop valve from the master so it wasn't too bad. Two lines shouldn't be that hard to fab up.
Old 11-23-2009   #16
twack
twack's Avatar
well yet another bay picture. My buddy dustin (123abc) came over and we did an ABS delete with AutoZone brakeline tools. I was suprised we got all those fittings loose. It turned out awesome, not sure what else i can rip out of the bay that i dont want.
heres all the abs that got tossed after we reused a few lines
Finally got that stock radio deck in there, it had some pioneer speakers so it sounds great. Kinda crazy that a deck is working after 18 years
To go along with the battery drop i got a $25 walmart lawn tractor battery its much smaller, lighter, and still does the job
and to top it off a lil paint to make it look like the pacesetter muffler
Old 11-23-2009   #17
Clean and budget, perfect beater!
Old 11-24-2009   #18
twack
twack's Avatar
i broke down and bought a part for it. I got a o2 housing with external dump.
got it installed
decided to toss on my C.O.P. the stock coil pack was questionable
and just incase you didnt know what my engine bay looked like heres another pic for ya
Old 11-24-2009   #19
External dump on a 14b? That ought to sound interesting...
Old 11-24-2009   #20
twack
twack's Avatar
haha it gets better then that. its a dump on stock exhaust on straight wastegate pressure. So its going to be dead silent then soon is i hit the gas it will be loud as hell. had to have some fun with the car
