Old 01-16-2006   #1
Black97civic
35mpg
My conquest finally runs!!!
I found the problem with my starion. It runs better when you unplug the electronics that run the car. Me and Andy (conquests) got my quest running tonight, and all it took was unplugging the Mass Air Sensor.
I think all this thing needs is a Holley Double Pumper Carb and it will run 11's.
Old 01-16-2006   #2
Re: My conquest finally runs!!!
Mod list?
Old 01-16-2006   #3
MustGoFaster
MustGoFaster's Avatar
Drives: A big dirty V8
Reid never lies. The ECU runs the clock and that's it!
Old 01-16-2006   #4
LOL, glad she is running!! Are you going to try a different MAS? Wire in a 1G DSM one, but do it the way Reid did it (I think it just required a few wires to be swapped around).
Old 01-17-2006   #5
Shotgun!
Totenritt
Shotgun!'s Avatar
Yeah, homes. Use a 1G DSM MAS and it'll run better than ever. That doesn't say much in your case but it will be good either way.
Old 01-17-2006   #6
Black97civic
35mpg
I have a 1g mas, not modified at all, and it idles just fine, so that is better than the 2 starquest MAS's I had sitting around.
Reid, you got a wiring diagram anywhere for the real way to do the 1g mas without the 1g pigtail?
And yes, everytime we unplugged something (TPS, ISC, MAS) it actually ran better, and when we got to the MAS it ran fine.
Mod list:Lowered 1.5", poly suspension bushings, 1G dsm mass air sensor, 1g dsm K&N (thanks hughes), 2.5" catless Turbo-Back exhaust being made, open downpipe for now, Ported and Polished Non Jet valve head, 7.5:1 Hyper-U pistons, non-stock cam, dunno what it is, Balance Shafts Eliminated, All Emissions Equpiment eliminated, Slotted Rotors and Metal Matrix Pads, walboro 255 fuel pump, aeromotive "1000 hp" fuel filter, -6 braided stainless from the pump to the fuel rail
Old 01-17-2006   #7
Shotgun!
Totenritt
Shotgun!'s Avatar
The wiring diagram is in my driveway. I think I have one in the garage on top of the old chairs, too.
Old 01-17-2006   #8
Black97civic
35mpg
you have a spare one that is wired up already??
Otherwise I will want to see that, or maybe have you write it down for me so I know how to wire mine up.
I can just switch my wires around in the starion plug, right?
Old 01-17-2006   #9
Shotgun!
Totenritt
Shotgun!'s Avatar
no. the starion plug is worthless. Use the DSM plug.
Old 01-17-2006   #10
slowbubblecar
Big Turbo Monster
slowbubblecar's Avatar
Drives: GTS and E55
Where did you get that? I have only heard of the aeromotive 100 and 10 micron filters.
7/25/09
Old 01-17-2006   #11
Black97civic
35mpg
Reid, do you have any extras I can purchase?
This is the one I have, it is a 10 micron, but will supposedly support 1000hp, so I figure thats what I should shoot for...
Old 01-17-2006   #12
slowbubblecar
Big Turbo Monster
Drives: GTS and E55
You will need a bigger pump bigger than 6an line for that. Atleast it runs though.
7/25/09
Old 01-17-2006   #13
Black97civic
35mpg
Oh yeah, I know that for sure. I will also need a turbo that flows more than 320cfm, more than 2 injectors, etc. etc.
Old 01-17-2006   #14
Kougar
Drives: 06 RSX
Nonsense.
Just turn the magic duty cycle up more.
Old 01-17-2006   #15
Black97civic
35mpg
6000% oughta do...
Old 01-18-2006   #16
cudvig
Rainbow Boy
cudvig's Avatar
Drives: 96 Civic HX
2 injectors=the suxor!
-Colin
