Old 01-27-2006   #1
What tial WG Spring are you using?
I just ordered a Big Blue, 1 bar spring, because the one that came with the WG is the .5 bar small green one. I was wondering, Should i just combine them on my wastegate which would be my desired boost level. I would like to run 21psi. (1.5 bar = 21.75 psi) then should i just get rid of the MBC and let the wastegate control the boost?
Old 01-27-2006   #2
Re: What tial WG Spring are you using?
Just use the 1 bar and use your MBC to go higher if needed. That will allow you to go up and down but not below 1bar (14.5psi) whenever you want.
Old 01-27-2006   #3
If you always want to run 22psi then yes, use both springs. That seems a bit high for a car on CA pumpgas though, have others been running that much with sucess?
Old 01-28-2006   #4
I dont know but after tonight im fucking pissed and NEED to get tuned. BADLY. my car was pulling 10.4 1/8th mile times and was seriously bogging off the line. I need a tune and a manual trans.
OT: Can a 1g manual transmission fit on a 2g gsx?
