Old 02-03-2006   #1
TurboDomestics
TurboDomestics's Avatar
Car wont start.
I crashed my old laser, and then bought a talon shell, and swapped everything over.
I crashed the laser about 5-6 months ago, so the motor hasnt ran in awhile. Everything worked beautifully on the laser, so I know that everything I pulled off the laser is good.
Now heres my problem:
-The car will not start, it turns over but it will not start up. I tested my coil pack, and it checked out ok, I have brand new plugs and wires, so it should be getting spark. It gets fuel at pressure at my FPR, but no fuel enters the cylinders. I know my ECU is getting power, (Stock boost gauge goes to 0, and the CEL comes on for 5 secs). And after a visual inspection of the ECU it does not appear that the capacitors have leaked.
I was thinking that it was maybe the CAS, but that worked wonderfully on my laser. So maybe its the Injector resistor box? I dont know. How do I go about testing the resistor box? what do the pros think could be causing my problem?
thank you very much!
-Charlie
4G63 0, Charlie 3
