Old 02-07-2006   #1
Enes
Enes's Avatar
Oil feed line?
Ok, i have a pte 50 trim, and i noticed since i put it on that the car will smoke blue crack sometimes, and not the other times...
I don't remember which oil supply line i have i think its the bigger one that will
cause the higher preassure in the oil sections and blow by the seals..
which one should i get? anyone know?
Also i need 2 longer studs on the exhaust manifold that are the little big bigger, they are the 2 outside that are thicker... anyone know where i can get those? (i put in the 1/2" spacer on there)
-E
Old 02-07-2006   #2
Re: Oil feed line?
Where is your feed line from? If it feeds from the head, you'll see lower pressure. If you're feeding from the oil filter housing, you'll see higher pressure (which is what you want for the journal bearing PTE turbos, I believe).
Old 02-07-2006   #3
Re: Oil feed line?
Feed it off the oil filter housing. If you are looking at it dead away (oil filter to the left) you want the upper right port.
Old 02-07-2006   #4
Enes
Enes's Avatar
Re: Oil feed line?
It is from the oil filter housing the upper right one...
i guess it'll just keep on smoking then...
Old 02-07-2006   #5
Re: Oil feed line?
Weird...maybe you got one from a bad batch or something? The studs should be a M10x1.25, something in the 40mm long range should be large enough.
Old 03-07-2006   #6
Re: Oil feed line?
-E
Looks like enes is back to post whoreing. LOL
