Old 03-03-2006   #1
dead car
I don't know why, but the car won't even get electricity.
the car has a battery relocation kit installed on it when i got it. I added some switches for fans, fuel pump etc etc. They all worked. Every time we hooked up the battery, the car would beep (HKS turbo timer). But, tonight, that little fuse box that usually attaches to the battery was touching the frame somehow, as it was only wrapped in masking tape (not of my doing). It sparked, and reset the ecu (EMS). after re-wrapping that damn thing, i finally go to start the car, and all power is gone. The switches don't work, and they run straight off the battery, with a fuse. the battery has good power, and the battery fuse up front was zapped, but after replacing that, nothing changed. I can't see any other fuses burnt out, and as far as I can tell, power is still making it's way from the battery. I know that the cut-off switch is fine, as there is power after the switch, but as far as anything else, I don't know. any ideas?
-A. Swift
