Old 03-06-2006   #1
rst95eclipse
Trouble getting axle out (Pics)
So I'm in the process of taking my passenger side front axle out of my 95 GSX, so I can pull the motor. The bearing housing is bolted directly to the transmission. 4 bolts hold the housing to the tranny. The bottom right bolt is giving me trouble. I've broke the other 3 loose, but there is no possible way (that I know of) to get to it. The lower control arm (directly under the axle) has framing that goes up and over where it bolts to the frame, kind of like a shield. Please someone help me with this problem. There's a 14mm socket on the bolt that needs to be broke loose.
http://i6.photobucket.com/albums/y21...pension004.jpg
http://i6.photobucket.com/albums/y21...pension005.jpg
http://i6.photobucket.com/albums/y21...pension006.jpg
http://i6.photobucket.com/albums/y21...pension007.jpg
http://i6.photobucket.com/albums/y21...pension008.jpg
http://i6.photobucket.com/albums/y21...pension009.jpg
http://i6.photobucket.com/albums/y21...pension010.jpg
http://i6.photobucket.com/albums/y21...pension011.jpg
rst95eclipse is offline   Reply With Quote
