Old 01-07-2004   #1
TurboGirl
My 90 Laser RS, details posted under "running rough"
Finally got it datalogged and here is what came up...
* Air Flow Sensor
* Air Temp. Sensor
* Barametric Temp. Sensor
* Injector Circuit??
I was told by the kid who datalogged it that the first three are all a part of the MAS, he wasn't sure about the Injector Circuit.
We've changed the MAS 3 times with different ones, can't seem to figure out the problem.
Anyone have any ideas???
TurboGirl is offline   Reply With Quote
Old 01-07-2004   #2
Sounds like some bad wiring possibly or the ECU may be bad. The caps in the ECU tend to leak and cause all kinds of damage. The first 3 are all in the MAS. Clean the connections and check the continuity between the end of the MAS plug and the ECU plug to make sure a wire isn't broken.
Old 01-08-2004   #3
acidrumz
ohkay, the first 3 is located in the maf sensor. check/replace with a known working one.
the injector circuit is the wire that plugs into your injectors. should be 4 for them to each injectors. check for loose/broken/cracked wires.
you can check your ecu too. replace with a known working one to see if the cel clears your first 3 cel.
goodluck.
later.
edit, i meant there are 4 plugs to each injector.
Old 01-08-2004   #4
There are only 2 wires per injector.
Old 01-10-2004   #5
TurboGirl
Alright...
We've checked the MAS and the Injector Circuit and all seems good. I am really confused because we can't seem to figure it out. I'm trying to get a hold of a logger again but not have much luck with that either. Any suggestions of where I can look to figure it out, or someone I can talk to.
Thanks
Old 01-10-2004   #6
LightningGSX
Hellbound
Originally posted by JET@Jan 7 2004, 10:38 PM
Sounds like some bad wiring possibly or the ECU may be bad.Â* The caps in the ECU tend to leak and cause all kinds of damage.Â* The first 3 are all in the MAS.Â* Clean the connections and check the continuity between the end of the MAS plug and the ECU plug to make sure a wire isn't broken.
I'll second this.Check the grounds also, specifically the MAS ground.Bad grounds can cause all sorts of weird problems.
-Nulli Secundus-
