Old 04-06-2006   #1
GVR-4579
Suspension noise
well my VR-4 is making a clunking noise when you drive over bumps on the left side, after inspection of the susepension i decide the ball joint should be replaced. well that didnt fix the noise even tho it was bad. so now i am trying to find what else could be wrong. i am gonna rip into the suspension tomorrow. any one have any ideas or experiences similar?
erik
Old 04-06-2006   #2
clean2g
Boost Junkie
clean2g's Avatar
Drives: I teleport
Re: Suspension noise
Have you done any suspension upgrades? Shocks/struts, springs, etc?
Old 04-06-2006   #3
DSM_421
tag
Old 04-06-2006   #4
GVR-4579
its got some lowering springs, i was thinking maybe the strut could have gone bad from them.
Old 04-06-2006   #5
tim
tim's Avatar
I am not sure how the struts mount in the strut tower but a noise like you are explaining can be often caused by a worn strut mount or bearing plate. In order to have a strut actually make noise you would have to seriously damage it or ir would have to be broken.
Are the sway bar links still in tact and tight?
Old 04-06-2006   #6
GVR-4579
the sway bar links are a bit loose i think thats my next shot at fixing the noise. thanks for the ideas.
Old 04-06-2006   #7
tim
tim's Avatar
You would be surprised at the amount of noise a tight but rotted swaybar link will make. Replace them with some poly bushings and benifit from it while you are at it.
Old 04-06-2006   #8
GVR-4579
well i dont know about poly bushings, mine are like mini tierod ends, but yea that wil be my next try unless someone else comes up with a brilliant idea
thanks
Old 04-16-2006   #9
GVR-4579
OK so i went ahead and foudn that my control arm bushings were getting really bad, i put in new ones and they didnt help. Damn! I also figured out it was not my sway bar links either. I think my next step will be to rip out my strut assemblys and make sure there isnt anything caught in my springs, and clean the spring perches. Also wile apart i am gonna check the strut mounts. Any other ideas before i go crazy?
Old 04-16-2006   #10
Pimpin Dsmstyle
Br0k3N
Pimpin Dsmstyle's Avatar
Just go crazy. Suspension work isn't so fun either
- Josh L.P.
