Go Back   MitsuStyle > Hosted Support Forums > Brookdale Mitsubishi
Old 04-06-2006   #1
Pimpin Dsmstyle
Br0k3N
Pimpin Dsmstyle's Avatar
Wtb Asap
The car is a 90 FWD turbo eclipse GST. I'm not sure what year engine is in there (should be a 90). If its 91-94, are all of the parts listed the same anyways? If Nick isn't familiar enough to answer, someone else? Thank you! Sorry, I'm a little rusty. I haven't been into the game in over 6 months.
WTB ::
Balance shaft eliminator kit (including the mirage bolt plug thinger)
Full timing kit. Belt and all accessories. (including bolts for these parts)
1990 oil filter housing crush washers for external oil cooler lines ( x4 i think)
Full Valve cover bolt kit.
Biss screw ( located in the throttle body)
Orings / grommets for all 4 injectors
Throttle body gaskets (however many required)
This sounds a bit odd but I'd almost rather use all new bolts for the timing. Is there a way to find out how many bolts and the cost for all of the bolts that hold the tensioners / pullies on? If that's a pain in the ass, don't worry about it. Anyways, I think the bolts come with the tensioners
I could be there to pick up whatever you had in stock Friday the 7th. Anything that you don't have in stock - I could pick up the next time you're open and the items are available. So anything you don't have onhand, ORDER UP PLZ! I will need these items no matter what
Last part that I might need. Oil pump. I'm not sure if I'll need this so if you don't mind stocking it, order it up. Someone will need one I'm sure either way. You should order like 5
- Josh L.P.
Old 04-06-2006   #2
Pimpin Dsmstyle
Br0k3N
Re: Wtb Asap
I'll check with DSMstyle around noon.
- Josh L.P.
Old 04-07-2006   #3
Nick G
Nick G's Avatar
Snow Storm Champion!
Drives: 94 v10 Ram
Re: Wtb Asap
I'am working on this,its a little much just give me some time 30/45min
thank you!!!
Nick
Nick G is offline   Reply With Quote
Old 04-07-2006   #4
Nick G
Nick G's Avatar
Drives: 94 v10 Ram
Re: Wtb Asap
You might want to re think your list, I went through all the stuff on your list I do stock the timing parts but not bolts. Everything on your list comes out to $759.95 we will have to go through and see what you dont need
just let me know
thank you!!!
Nick
Old 04-07-2006   #5
Pimpin Dsmstyle
Br0k3N
Re: Wtb Asap
K skip the oil pump and extra parts. Just the basic list will have to do. If I need more, ill have to order on monday.
- Josh L.P.
Old 04-07-2006   #6
Pimpin Dsmstyle
Br0k3N
Re: Wtb Asap
- Josh L.P.
