Closed Thread
Old 04-28-2006   #1
96 Gsx Awd
96 Gsx Awd's Avatar
Send a message via AIM to 96 Gsx Awd
Main bearings and Rod bearings
I was told the LSE could supply me with king bearings. Is this brand even good or should i go will a different one? Let me know what you guys think.
Finally tuned and fully built, Takes a lot of time,patience and money!!
96 Gsx Awd is offline
Old 04-28-2006   #2
Pimpin Dsmstyle
Br0k3N
Pimpin Dsmstyle's Avatar
Re: Main bearings and Rod bearings
He needs standard sized bearings I'm pretty sure. You could have him come up to LSE and spec the crank. It needs to be polished anyways. I told him to use king bearings because I'm pretty sure that's the bearing of choice around these parts. Correct me if I'm wrong for some reason.
- Josh L.P.
Pimpin Dsmstyle is offline
Old 04-28-2006   #3
cudvig
Rainbow Boy
cudvig's Avatar
Drives: 96 Civic HX
Why not Clevites? or ACL? They are cheap and do just fine?
-Colin
cudvig is offline
Old 04-28-2006   #4
Pimpin Dsmstyle
Br0k3N
-Colin
What bearings do we use that aren't cheap... This isn't your problem.
- Josh L.P.
Old 04-28-2006   #5
Clevites are fine, you just have to double check their machining since at least two sets I've used had rough edges. Not tough to fix, but they more or less should be drop in, you should be inspecting any part you put in your engine whether they have a good rep or not. ACL and King seem to be pretty good.
Goat Blower is offline
Old 04-28-2006   #6
http://www.dsmtuners.com/forums/showthread.php?t=220380
Jakey is offline
Old 04-28-2006   #7
Yes, we can order you kings. We can get you standards or any size under you need. It would be best to have the crank work done first, then we can mic it and see what size you need.
After all the bearings I"ve played with here and QPR I still perfer Kings and ACL's. The clevites with the burs and the material change-up I do not like, and the oems are usually decent, but not a performance bearing.
niterydr is offline
Old 04-29-2006   #8
96 Gsx Awd
96 Gsx Awd's Avatar
Thanks jake it helped alot
Closed Thread
