Old 05-19-2006   #1
HiImBrian
HiImBrian's Avatar
Drives: the girls crazy
Autometer???
I've heard a lot of bad things about autometer boost gauges. I've got one thats about 7psi low. Is it true that they are not as good as other gauges??? If so, what is the reccomended gauged under $100?
pics or gtfo
Old 05-19-2006   #2
Re: Autometer???
I have had many Autometer Boost gauges and have never had a problem.
Old 05-19-2006   #3
Re: Autometer???
Stewart Warner Performance
Old 05-19-2006   #4
Re: Autometer???
VDO are nice and cheap also. My autometer fell apart and read about 2 psi low.
Old 05-19-2006   #5
Re: Autometer???
Yeah many people complain about the Autometer Boost gauges not sittng on the zero when off, and their EGT probes suck dick. As said above, VDO makes very inexpensive, but decent gauges. Stewart Warner is a step above Autometer, but they "look" about the same.
Old 05-19-2006   #6
HiImBrian
HiImBrian's Avatar
Re: Autometer???
It's just hard to find anything beside autometer. Everybody is selling autometer and not much eles!
pics or gtfo
Old 05-19-2006   #7
Re: Autometer???
No it's not. Call up LSE, DB, or Elite. I ordered all of my SWP gauges from Elite about a year ago. If you bleed Slowboy, they also sell SWP.
Old 05-19-2006   #8
HiImBrian
HiImBrian's Avatar
Re: Autometer???
I guess I never even thought of that! Thanks.
pics or gtfo
Old 05-19-2006   #9
Re: Autometer???
The most accurate I've found has been the Greddys. Too bad you have to convert your mind to metric. Boo.
I'm probably going to switch certain gauges to Autometer since I'll be replacing my speedo and tach with their bigger, more accurate than stock gauges. The factory tach is a joke once you start making any real power.
Old 05-19-2006   #10
Re: Autometer???
Similar to this?
Old 05-19-2006   #11
tim
tim's Avatar
Re: Autometer???
He said speedo and tach Not water and oil pressure
I would like to do my gauges like that pic though. I found out today that my temp gauge doesnt function properly The maiden voyage didnt work out too well.
Old 05-19-2006   #12
Re: Autometer???
Well yeah, you get the point. I believe the pictures are of a cluster that Nick Drake of Pina Motorsports did but I'm not for sure. I got them off of Tuners about 3 years ago.
Old 05-20-2006   #13
Shane55113
Now 20% less Racist
Shane55113's Avatar
Re: Autometer???
i have an autometer boost gauge and i like it, the only problem i have with it it once in a blue moon when i start the car it stays at zero instead of going into vac, but once the car gets warmed up it acts normal again or i just boost it real quick and hard and it goes back to normal.
Old 05-20-2006   #14
Onefast99gsx
Re: Autometer???
I run Autometer boost & EGT gauge. Have NEVER had a problem.
Old 05-21-2006   #15
Thor06
11 Seconds to Freedom
Thor06's Avatar
Re: Autometer???
I have only heard of one problem with autometer guages until I read this thread. All the people modified enough to use any guages up here have autometer ones, as well as all of the stock cars I ever looked in. I dont know, thats what my Talon will be getting.
Old 05-21-2006   #16
HiImBrian
HiImBrian's Avatar
Re: Autometer???
Ok thanks, I feel a lot better about it now. The main reason I posted this thread was because my autometer boost gauge is about 6psi off. It came on my car when I baught it a few months ago. So it could just be old idk. I'll just get a new autometer gauge. thanks!
pics or gtfo
Old 05-30-2006   #17
TsiEagleTalon92
TsiEagleTalon92's Avatar
Drives: 2022 Hyundai Palisade
Re: Autometer???
All my autometers work just fine and read accurately except my EGT gauge which has a bad harness. My oil pressure gauge which the light doesnt work and makes the other 5 dimly glow, doesnt work at night unless I unplug it and plug it back in. Speaking of which if anyone who has an OPG that would like to maybe sell cheap I might be the man.
Old 05-30-2006   #18
x-pride
x-pride's Avatar
Re: Autometer???
So, if your gauge is not working properly. How do you know your 6PSI off? I hope you are not comparing your stock guage with your factory gauge!
Old 05-30-2006   #19
HiImBrian
HiImBrian's Avatar
Re: Autometer???
haha I'm not that stupid! I threw it on a dyno and they hooked it up. Thank's to Josh at LSE my car hasn't blown up yet!
pics or gtfo
Old 05-30-2006   #20
Re: Autometer???
like this?
-A. Swift
