Old 06-04-2006   #1
New Signature Policy
I would first like to suggest everyone visit the new forums page on the main website. http://www.dsmstyle.com/forums.html
This is where the layout of our new rules structure and membership structure will be implimented. I think they clearly lay out the ground rules for the site in a clean manner. The one I'd like to first foucs on is the signature policy. This will go into effect ASAP and we suggest anyone with any questions post up in here and we will do out best to answer them in a very quick manner. Below you can find the new signature policy..
Signature Size
- To keep the page loading time and visual annoyance factor down to a minimum, ensure your graphical signatures do not exceed a maximum of 200x450 pixel image size limit with a max file size of 50kb. Alternatively, five lines of text can be used as a signature. Do not pad out your text lines with blanks lines. A line of text is defined such that it does not wrap when viewed at a resolution of 640x480. If these limits are exceeded then you may be contacted by a moderator requesting an amendmant to your signature. If none is made within a reasonable period of time, then a moderator may remove your signature from your profile.
