Old 06-26-2006   #1
TsiEagleTalon92
TsiEagleTalon92's Avatar
Drives: 2022 Hyundai Palisade
Wideband Wiring
Can anyone help me out with installing my wideband? I don't know where to find a good ignition power wire to use and I need to know where to wire in my narrowband output wire. The easier the directions, the happier I will be. (I'm not too good with net directions)
Old 06-26-2006   #2
TsiEagleTalon92
Re: Wideband Wiring
Ok I have the power hooked. I still have the problem of there being continuous readings it keeps the same numbers without fluctuating. 14.78 and 14.86 it what it jumps around at. Could this be a bad ground or not a solid connection?
Old 06-27-2006   #3
EclipseGST
EclipseGST's Avatar
Drives: Short Bus
Re: Wideband Wiring
Might be helpful if you let us know what wideband you have...
It could be either a bad connection or a bad ground. Check everything.
Originally Posted by shoutbox
Old 06-27-2006   #4
TsiEagleTalon92
Re: Wideband Wiring
Oops sorry, Never thought of tellin, I thought they were maybe similar, But I did check everything and everything still wasn't working but I have come to the conclusion that I think I managed to disconnect the harness when trying to get everything snug so now it works. Plus I redid some of the wiring so it is 100% right so who know what happened. Sorry this is a wasted thread.
