Old 07-13-2006   #1
Opinions of the following turbos...
OK im gonna list of some of the more common dsm used turbos just post your opinion of each of them or some of them or whatever... Just looking for responces like what is your overall opinion either from what youve heard about them or what you have expirenced with them. IM likely missing a couple but add if you want.
T-25
T-28
14b
Small 16G
Big 16G
18G
20G
50Trim
60Trim
60-1
GT35R
GT42R
Old 07-13-2006   #2
slowbubblecar
Big Turbo Monster
slowbubblecar's Avatar
Drives: GTS and E55
Re: Opinions of the following turbos...
I loved my old hahn super 20g. We had a new PTE 50 trim before also and had a terrible time getting a tune on pump gas with it. It always knocked. GT35R-we'll see pretty quick.
7/25/09
Old 07-13-2006   #3
big 16g was a good turbo. 60-1 waste of time imho. I'd just go with the scm61. gt42r is a dyno numbered turbo, not too street friendly, but likes higher trap speeds. gt35 is a good turbo, basically a 61 (from what I know). 20g is about the same as the new evo twin-scroll turbos, in terms of power.
-A. Swift
Old 07-13-2006   #4
I loved my 20G. Id say 20G or 50trim FTW on a street car.
Old 07-13-2006   #5
T-25
SMALL
T-28
SLIGHTLY LARGER
14b
Solid, but small and stock
Small 16G
getting larger, reliable
Big 16G
better off with an evo 16g
18G
Old school, works well
20G
I like pte 50 trims better
50Trim
Good street turbo
60Trim
Decent turbo, 50 trim is better
60-1
Horrible compressor map
GT35R
Great street setup, tad large for some people
GT42R
Despite what people think, not a street turbo.
Old 07-13-2006   #6
T67
Good
FP 3575
Better
Old 07-13-2006   #7
T-25
Torquey
T-28
Why bother?
14b
Enough for 10s in the 1/4 mile.
Small 16G
Noticeable lag.
Big 16G
Sounds a bit big.
18G
All the power of a 16G with the lag of a 20G.
20G
Unstreetable.
50Trim
Is this a T3/T4?
60Trim
10 more trim than the 50-trim.
60-1
Good for a low boost V8s.
GT35R
Is this some new fangled turbo? Is the "R" for race?
GT42R
You got a semi there?
Old 07-13-2006   #8
Never been a fan of the 50-trim, but I think either the Big/EVO 16G or 20G makes the perfect street turbo.
Old 07-14-2006   #9
Thor06
11 Seconds to Freedom
Thor06's Avatar
T-25 = Gay
T-28 = Just get an Evo III 16g
14b = Good starter
small 16g = Why?
big 16g = Might as well go Evo III 16g
Evo III 16g = Good "mild street" turbo, lower power goals
18g = Evo III's are cheaper and make the same power
20g = good turbo, but its too fuckin expensive
50 trim = good alternative to the way more expensive 20g
60 trim = might as well go 60-1
60-1 = good for a bit more power
GT35R = on the big side, I wouldnt street it
GT42R = too damn big
Old 07-14-2006   #10
At-Least-It's-An-Evo
At-Least-It's-White-Again
At-Least-It's-An-Evo's Avatar
Drives: 98 iVTEC
Tom, a 50 trim or a 61mm most likely fits your needs for going through the gears. The 50 trim might spool better in reverse.
'04 Honda Ricer: stock
Old 07-14-2006   #11
I'll only comment on the ones I've personally used.
14b: decent for a stock turbo, holds decent boost, and until you ride in a car with something bigger, you're sure it's the fastest thing out there! holds 18-20psi to redline just fine. Very reliable.
Small 16g: probably what the 14b should have been, except for the boost creep. Nice little turbo, spools excellently and provides good power. My 2g came with one on it, and I was really happy with it while I had it. Had shaft play along the line of the shaft like crazy, yet hardly burned any oil and still spooled awesome.
20g's:
Bastard 20g: big power in a small package. Spools similar to a big/evo16g. made 280whp @ 22psi @ LSE, 338whp @ 25psi@ DB.
Hahn Super20g: 20g power w/ kick-ass top-end. Spools much slower than my bastard 20g. ~4000rpms. Made 280 whp on a mustang dyno @ 18psi on pump gas
The Td06 20g is my favorite turbo in the world, because of how reliable they are. Anytime I look at a used T3/T4 setup it 'just got rebuilt' or some shit. There are reliable cases too.
SCM61: big power for little money. Probably my next turbo.
Old 07-14-2006   #12
Turbocharged
Ive only run a t25, 14b, 20g, and a 50 trim.
t25 = Worthless
14b = Best bang for the buck if you are looking for 12's.
20g (td05h) = I didnt really care for it. I was expecting more top end.
50 trim = Pulls better than the 20g without much of a difference in spool.
My next turbo will have a 60-1 compressor. Im undecided on the specifics.
Turbocharged is offline   Reply With Quote
Old 07-14-2006   #13
npaulseth
I like my SCM61. It sounds cool when I idle.
Old 07-14-2006   #14
Then you need to read some of the above posts.
14b nice little stock turbo
16g not really any different than a 14b
50 trim - excellent street turbo for a 2.0
SCM61 - getting on the edge of my definition of streetable for a 2.0, great for a 2.4
T67 - probably my next turbo on the 2.4 if this one pukes. My car isn't all that streetable anyway, so screw it
Old 07-14-2006   #15
Im liking these opinions.
Well heres mine so far:
T-25 - great turbo until 3000 rpms.
T-28 - Little bit bigger compressor and exhaust wheel. Cops cant tell the difference between this and stock.
14b - Heard good things, but looks way too small.
Small 16G - Decent Spoolup holds boost well.
Big 16G - More of these have been sold then Beatles records.
18G - Acura Integra turbo all the way.
20G - I know Slowwhite was having major issues with this one.
50Trim - The first time i drove with this on my old GSX i was freaked the fuck out when it pulled. But soon realised that its a lag monster on an automatic dsm. We will soon find out what she does with a FMIC and a Manual Tranny.
60Trim - No clue what one feels like.
GT35R - Big expensive turbo, heard great things though.
GT42R - Serious baby eater. and if i wanted 900+ HP this is the one i would likely go with. But who wants 900 HP?
Old 07-14-2006   #16
You will be happy with the 50 trim on a manual. I consider it the perfect 2.0 street turbo.
Old 07-14-2006   #17
I cant wait, but Im going to do this one right. Im only missing one peice which is a 3" intake pipe, if anyone knows where i can get one for cheap let me know please. I have all of the piping (welded and painted) for the FMIC, the couplers and t-bolt clamps, and the motor is ready for it, once i get the Intake pipe, ill install everything, and take it directly to the dyno to tune dsmlink. I have waited 4-5 months just staring at that turbo in my room, next month i will have enough extra money to get everything done as well as get a good set of tires.
Old 07-14-2006   #18
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
what about the direct bolt on for 2g's, Forced Performance t-28 killer, any thoughts on that
Old 07-14-2006   #19
Ultimate 2g sleeper.
Old 07-14-2006   #20
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
thanks I just wanted something with a good bite but keeping the direct bolt on and stock appearance... So you recomend it??? FP says they got into the 11's with 21 psi.
