Old 07-13-2006   #1
clean2g
Boost Junkie
clean2g's Avatar
Drives: I teleport
Lagging issues
I'm having some annoying lagging issues and also a mushy clutch pedal that lasts for the first 10 minutes that I drive. I have changed everything humanly possible that I can think of: Clutch master and slave cylinders, SS clutch line, transmission was rebuilt 8,000 miles ago and new clutch was put in 20,000 miles ago. The lagging is not consistent; some days it's there some days it's not. I can't figure out if the clutch is slipping or if there's a boost leak. Right before spool up there will be an obvious lag/bog and then the turbo starts spooling. The car is a 97 GSX with 108,XXX miles. Mods are: Shep stage 1 rebuilt trans, ACT 2600 clutch w/resurfaced flywheel, mbc, catback exhaust, bov, intake, hahn sidemount ic upgrade, and ic hardpipes. Any advice/input greatly appreciated.
Old 07-13-2006   #2
s1ngletracker
s1ngletracker's Avatar
Drives: A BMW
Re: Lagging issues
7 bolt? You may laugh at me, but check for crankwalk. I had tons of clutch issues, and my car was walked bad.
Old 07-13-2006   #3
clean2g
Boost Junkie
clean2g's Avatar
Drives: I teleport
Re: Lagging issues
Do you recommend a place/someone for checking for crankwalk? I know there's a vfaq but I'm afraid I'll jack something.
Old 07-13-2006   #4
xveganxcowboyx
Wanker
xveganxcowboyx's Avatar
Drives: 95 M3
Re: Lagging issues
The problems could be seperate. What does your fuel system look like? Have you logged anything?
Old 07-14-2006   #5
Turbocharged
Re: Lagging issues
Just drop the oil pan an measure the thrust bearing clearance.
Was your clutch hydraulic system properly bled and adjusted?
As for your lag issue, check for exhaust leaks before the turbo.
Turbocharged is offline   Reply With Quote
Old 07-14-2006   #6
Turbocharged
Re: Lagging issues
I agree, the problems sound separately related.
Old 07-14-2006   #7
Re: Lagging issues
The english language kicks ass
Just measure the play on the crank pulley to see about crank walk. You will need a depth mic, dial indicator or a caliper to take the measurement. Pull the pulley out, take a measurement, then push it in and take a measurement. The difference is the amount of thrust bearing play that you have.
Old 07-14-2006   #8
s1ngletracker
Drives: A BMW
Re: Lagging issues
^^^ do what Jet says.
Old 07-14-2006   #9
Turbocharged
Re: Lagging issues
HAHA, I wrote that in a hurry. I guess it would have made more sense to say that the problems were unrelated instead of "separately related"... its too early.
JET's right. I guess I like doing things the hard way.
Do the rpm's drop when the cluth is depressed? Do you here a ticking when you depress the clutch and hold it to the flood? Have you ever had a problem with the clutch pedal sticking to the floor when you make a left hand turn (the pedal will stop a few inches short)?
Old 07-14-2006   #10
Turbocharged
Re: Lagging issues
Sorry, double post.
Old 07-14-2006   #11
s1ngletracker
Drives: A BMW
Re: Lagging issues
in addition to this, do you ever have clutch chatter? do you ever have inconsistant clutch engagement height? those are symtoms i had.
Old 07-14-2006   #12
clean2g
Boost Junkie
clean2g's Avatar
Drives: I teleport
Re: Lagging issues
I have lifter tick but that's there no matter what. Pedal never stuck to the floor on a left hand turn.
Old 07-14-2006   #13
clean2g
Boost Junkie
clean2g's Avatar
Drives: I teleport
Re: Lagging issues
What is an "acceptable" amount of play, and what is not?
Old 07-14-2006   #14
Re: Lagging issues
Over .010" is out of spec. Over .025" and you had better call Houston, because you have a problem.
Old 07-14-2006   #15
clean2g
Boost Junkie
clean2g's Avatar
Drives: I teleport
Re: Lagging issues
lol, alright thanks, I'll take a look at it.
