Old 08-11-2006   #1
96 Gsx Awd
96 Gsx Awd's Avatar
Send a message via AIM to 96 Gsx Awd
Thumbs up I have some important questions please help??
Ok well my first question is if i have a 7bolt head with a 6bolt block which gasket set should i get?? My other question is i have a 7bolt flywheel and 2600 clutch, i was told i could use the clutch but you have to get a 6bolt flywheel. Is this true? the source was pretty reliable he helped me out with a lot of other things. How much power does it take away from using this set up a 7bolt head and 6bolt block? i heard you loose power this way, but the head and block are ported and bored. Thanks for the help guys.
Finally tuned and fully built, Takes a lot of time,patience and money!!
96 Gsx Awd is offline   Reply With Quote
