Old 08-14-2006   #1
iceminion
iceminion's Avatar
Exhaust Studs
So I am finally swapping my locked 14b with a 16g, and I have run into a couple problems:
a stud is broken off inside the head.
and several studs are stripped.
believe it or not, I didnt do it, the previous owner did, and I almost knew that this was going to happen when he told me he replaced the manifold "because it was cracked" it seems nobody knows how to use a torque wrench.
so, can I drill and tap the 8mm stud holes to 10mm?
what is the best way of going about this?
I could take the head off the car and bring it into a machine shop....it would be annoying as hell, but I could do it.
building a 3000GT AWD Turbo.
Old 08-14-2006   #2
Re: Exhaust Studs
i'd bring it to a machine shop, i hate using the drill on delicate things.
Old 08-14-2006   #3
iceminion
iceminion's Avatar
Re: Exhaust Studs
I think taking it to a machine shop would be the best idea also, the only trick now is to take the head off without having to re-do the timing, it involves making a jig, Rick Shinley told me about it a while ago, seems like a "good" idea, cant wait to try it.
Old 08-15-2006   #4
tim
tim's Avatar
Re: Exhaust Studs
Drill down the center of the broken stud and use an eazy out. Before you start wrenching on the easy out make sure to heat the head with a torch. Even a MAPP gas torch will do. You should be able to get it out that way. IMO, taking the head off should be the last resort.
Old 08-16-2006   #5
iceminion
iceminion's Avatar
Re: Exhaust Studs
Well, I got the head off, the intake valves are green and the exhaust valves are yellow, looks like this car had a bad head gasket at one point in its life. Anyways, the head is in the shop now getting helicoiled! Woot!
