Old 09-02-2006   #1
HiImBrian
HiImBrian's Avatar
Drives: the girls crazy
2g front bumper cutting
Anybody have any helpful hints or tips for me when I go to cut my front bumper? I'm getting rid of the lip that hangs in front of my fmic. How did you do it? What kinda of cutting tool did you use?
pics or gtfo
Old 09-02-2006   #2
Re: 2g front bumper cutting
Jig-saw, saws-all, high speed grinder with a cutting wheel will work well. I used the high speed grinder with a cutting wheel/disc.
Just don't go crazy, take your time.
Old 09-02-2006   #3
TalonFiero
moonshine power
TalonFiero's Avatar
Drives: 08 Saab 9-7x Aero
Yeah, I used a cutting wheel. I must have test fitted the bumper 20 times. Take your time or you will end up taking more than you want off. Also wear a respirator, the particles burn the shit out of your throat if you inhale them, probably real toxic too.
Jim
Old 09-02-2006   #4
HiImBrian
HiImBrian's Avatar
Did you guys cut it out or just grind it down? So far I've been griding the middle spot and the 2 side vents down.
pics or gtfo
Old 09-02-2006   #5
I left the black strip in place, just removed everything behind it. I also only removed enough of the front bumper opening to fit the i/c. No gaps around the i/c-bumper opening. It does require a lot of test fitting.
Old 09-03-2006   #6
rst95eclipse
I used a pneumatic die grinder with a cutting wheel. I'd recommend masking off the general area that you're going to cut, since the paint tends to peel off next to where you're cutting. I wouldn't grind, rather sharpie a line that you want to cut on the masking tape and follow that. Also, wear some kind of inhalation protection as stated before.
rst95eclipse is offline   Reply With Quote
Old 09-03-2006   #7
i used a die grinder with a cutting wheel, and a little jagged knife. You're cutting plastic, it's not rocket science. Just use whatever you got laying around that will work.
Old 09-04-2006   #8
The easiest way i have found (much easier and cleaner then using power tools) is simply a sharp as hell utility knife. It cuts through poly so easily. I tried using the cutter wheel and it just seemed to sloppy, the utility knife cut it in simply two strokes. so beautiful.
Old 09-04-2006   #9
HiImBrian
HiImBrian's Avatar
I got it done with a grinder and it worked really well. I'll probably die a little earlier from inhaling all those fumes even though I wore a mask.
pics or gtfo
