Old 09-07-2006   #1
Gsxedyou
Send a message via AIM to Gsxedyou
airfuel gauge
I got a airfuel guage and don't want to run to the maf. i had my friend running it to his computer but i can't get ahold of him. has anyone heard of where i can run it or have any ideas?
Gsxedyou is offline   Reply With Quote
Old 09-07-2006   #2
95talonracer
Finally Tuned...
95talonracer's Avatar
Drives: Spyder GSX
Re: airfuel gauge
Well it is hard to tell you when we dont know what it is and if it is even the wideband or the worthless one.
Amsoil Dealer
Old 09-07-2006   #3
Re: airfuel gauge
You are supposed to tap the o2 sensor voltage wire at the ECU. The guage is worthless though and really won't help you at all unless you keep a supply of glowsticks in the glovebox and throw the occasional rave at a stoplight which can be very fun given the right circumstances.
Old 09-07-2006   #4
95talonracer
Finally Tuned...
Drives: Spyder GSX
Re: airfuel gauge
The only other thing it can be used for is a filler to take the place of a pillar opening. No good for tuning or anything else.
Amsoil Dealer
Old 09-08-2006   #5
1slowdsm
Now 1 second.....slower!
1slowdsm's Avatar
Drives: 1993 Talon AWD
Re: airfuel gauge
That's why I got one! Biggest waste of my money though.
But I tapped mine from the ECU. Good light show for passengers who know nothing about cars ...lol
Old 09-09-2006   #6
Elementality158
Elementality158's Avatar
Send a message via AIM to Elementality158
Re: airfuel gauge
Yeah.... Cool lookin AF gauges... They are awesome.
Elementality158 is offline   Reply With Quote
Old 09-09-2006   #7
YiNYaNg
Hold Alt & press F4...LoL
YiNYaNg's Avatar
Re: airfuel gauge
lol yeap
Originally Posted by ecoli
Some cars are so slow that even the cops can't tell they are racing.
http://www.myspace.com/kounpheng
YiNYaNg is offline   Reply With Quote
Old 09-09-2006   #8
Re: airfuel gauge
tap into your brakes lines, and make sure to cut all 4!
Old 09-09-2006   #9
Elementality158
Re: airfuel gauge
Yeah. Exactly!
Old 09-09-2006   #10
Re: airfuel gauge
I think you should tap it to the dimmer switch .
Old 09-10-2006   #11
Elementality158
Re: airfuel gauge
But really. The way to do it is to tap into the anntenna.
Old 09-11-2006   #12
Gsxedyou
Re: airfuel gauge
thanks for the tips. i'll just tap it into the amp wire from my cd player so it'll bounce with the music...if i'm gonna throw a disco party, i should probably have it beat to the music.
Old 09-11-2006   #13
Re: airfuel gauge
Most A/F gauges can only handle 0-1volt. If you accidentally hook it up the wrong wire, you usually end up with a paper wieght.
Old 09-13-2006   #14
Elementality158
Re: airfuel gauge
tap into the o2 sensor. Im not sure where the best spot is. But im guessing anywhere would work. Still need to get mine.
Old 09-13-2006   #15
twack
It was a auto get over it
twack's Avatar
Re: airfuel gauge
i got one as a filler but i yanked the wires long time ago due to it being anoying (and was worthless) think i might put a 2nd boost gauge in cause i got it sitting around, just in case i want a second opinion on my boost.
Old 09-13-2006   #16
sleepy2lazy
sleepy2lazy's Avatar
Re: airfuel gauge
I tapped it into the o2 sensor wire. Its basically just for show, filler spot, and its there to impress the ladies.
-Correct me if i'm wrong guys, but If your car is basically stock, the A/F gauge is not that worthless. It reads does read your a/f. Then again, if you get an Apex'i Turbo Timer, you get all these for the price of one: o2 sensor, battery voltage, timer, and one more, can't remember.
Old 09-13-2006   #17
Elementality158
Re: airfuel gauge
Yes, for the ladies. Cuz anything flashing gets their attention. And it makes your car look cool. Even if your car is teal.
...Need to paint it soon.
Old 09-14-2006   #18
s1ngletracker
s1ngletracker's Avatar
Drives: A BMW
Re: airfuel gauge
Actually, I'd say for the purposes of just being a safety/peace of mind device, its not all that bad to have one. It basically can tell you if you're running rich or lean, but now how rich or how lean with any accuracy. But I've found that its good because if its in the red all the time, its probably time to hook up the wideband to see whats going on. my 2 cents.
Style's automotive engineer
Old 09-14-2006   #19
Re: airfuel gauge
Haha, this guys is funny.
Noobs, The "blinky" gauges read on a 0-1 volt signal. They are reading on a narrow band signal. They are only accurate around 14.7:1. Once you deviate from that air fuel ratio (which is Stoiciometric* ).
*Stoiciometric is the air/fuel ratio for gasoline where the correct amount of air and fuel are used to produce a "perfect" combustion, meaning the only thing leftover is water and carbon dioxide.
A wideband afr meter uses a lambda sensor (o2 sensor for those attempting to follow along) that reads on a 0-5 volt scale.
The issue with using a 0-1 volt signal is that the way the voltage is sent. If it is just a little bit leaner or richer than 14.7 you are hosed.
See the graph? Voltage deviates just a little bit from stoic and you are hosed. Yeah you are "lean" or "rich" but how much?
This is where a wideband 02 setup comes into play.
This is a much more accurate way of measuring what the oxygen level in the exhaust system really is.
I'll save on how an 02 sensor actually works and the differences between different types of 02 sensors for another day.
Just remember that the blinky gauges are virtually useless when trying to tune for power. An engine operates at stoic afr ratios (give or take a few .1 of an airfuel ratio) near cruising and idle.
Decel, accel, part throttle, and WOT all have different target AFR's.
***Pictures taken from a Innovative LM-1 supliment.
Old 09-14-2006   #20
s1ngletracker
Drives: A BMW
Re: airfuel gauge
^^ good information josh!
Like i said, safety device only. It will tell you if you are rich or lean so if its in the red, be careful, get a better measurement before beating on it. And absolutely don't tune with one.
